Trolling motor
ok this may be a dumb idea but I saw some cheap trolling motors today and got me thinkin about having it as a back up.
When my drive blew up I felt completely helpless and moving towards a jagged rocky shore.. It`s small enough to fit in the engine bay... question is would move the boat? even if for short distance or just to buy some time... http://www.cabelas.com/cabelas/en/te...questid=135789 |
I remember seeing a pic once of a turbine cat that installed a small trolling type motor on top of the trim tabs for maneuvering without firing up the turbines.
I am sure it would work in an emergency but I wouldn't rely on it to get you back to the trailer. |
If you are going to go that route spend a little more money on a 4hp gas and you might make it back to the ramp.You would need a big trolling motor and if it was windy i don't think you would move.
Where would you mount it? |
[ I thought about doing the same thing with a 5 hp outboard and some type of clamp on bracket for the swim platform. I dont think a trolling motor would move it very well, but I could be wrong.
Best one to get and it will move you a little, its the lightest one I know of
http://marine.honda.com/Products/ModelDetail/BF2 plus its a four stroke, so if you had to you could get fuel from you tank in your boat, you would need to rig something?? |
That would not even push your boat against the wind. You would probally need a 101 pounder and three batteries but then your cheap solution is no longer cheap.
Some of the reviews make me believe it could work ok in a jam
For a $100 I think I may try it. if its no good I`ll put it on a pool raft:drink: "pushes my 14' v bottom well even on a windy day with 3 people and motor and gear. does better than my old 35#moter guide that was 15 yrs old" "I bought this motor for a 12' john boat, it works great and moves the boat just fine. I troll on mountain lakes for trout and this motor goes all day on just one batterie." "I put this trolling motor on an all-welded aluminum jon boat. The boat is 14 1/2 ft with a beam of 56". It has a 25 Yamaha and with me, all my gear and one other person it has no trouble pushing this boat along at a good speed. It works well in weeds and is easy to operate. I would recommend this for any one looking for a good, reliable motor." "ok first of all this motor was perfect for what I wanted to use it for, I constructed a motor mount on the rear of my pontoon boat, 9ft, and I located two 9in +7in deep cycle batteries, first time on the lake with the 5 speed motor I was impressed with the thrust, and the mobility of the motor, and the telescoping control is a plus...quite and smooth, I would recommend this product to anyone..." |
Next time you're floating helplessly toward rocks, THROW AN ANCHOR!!!!!!!!!:lolhit:
It's a good excuse to move up to twins:drink:
Originally Posted by ICDEDPPL
(Post 3031500)
...I felt completely helpless and moving towards a jagged rocky shore..
| All times are GMT -5. The time now is 12:13 PM. |
