Turbinator Turbine Powered Catamaran
Eventually got started again on the turbine cat after many setbacks.
If all goes to plan and I pull my finger out she should be ready for the water this year. I created a little web site to document the build. www.turbinator.co.uk |
Very interesting were will the fuel tank be? Good luck Jo
I was wondering when we would get to see this.
Nice and clean installation. I see your containment blanket:drink: How did you know what height to install the drive? |
oh It was already rigged prior?
Hot shaft engine is much more boater friendly |
Fuel tanks have been moved down into the sponsons to keep the CG as low as possible.
I spoke with Rik at Arnesons about mounting the drive, I have managed to get the prop level and just below the spray rails. I wish I had started with a better hull but choice was limited at the time I started the build, there is one thing for sure she is light the whole package is around 3 ton. |
What size water pickup are you going to use?
I used one inch and had so much water pressure it blew the double clamped hose right off and began to sink the boat at 140mph. I ended up adding a 1- 1/4 dump with check valve right out of the strainer. Another note I never really have had to use the manual circulation pumps. Even in long no wake zones the oil temp would be below 190 degrees. |
I have been thinking about this, so far I have rigged it with a 1.25" hose double clamped. I went with a large circulation pump originally because I was going to water cool the exhaust.
I decided to keep it simple for a first project and ditched the water cooled exhaust due to the work needed to pull this off. Looks like I will have to fit a pressure dump to the stariner to keep the hoses in place. Not sure if I will be running at speeds of 140+ but we will have to see how stable she is when in the water. I am little concerned about the torque steer on a single engine setup. But there is only one way to find out! |
Not having water cooled exhaust can be dangerous. What are your plans to minimize the danger of fire?
Aluminum boat and a short stack should do it along with fireproof insulation on the lower section of the exhaust.
Originally Posted by 999JAY
(Post 3039707)
