Hour Meter on Mer Cruiser engine
I recently purchased a 1998 Baja 232 Islander with a Mer Cruiser 454. The hour meter shows 78 hours. My mechanic also stated that it shows 78 hours after looking at the engine. Have you ever heard of being able to change the hour meter on the boat meter like they do odometer rollbacks on a car. I purchased the boat and hope that I did not get ripped off. The motor looks clean but I am a rookie in the boating experience. Any experience with this hour meter being changed.
is it a efi engine? if it is the ecm can be scanned to check run time which is not affected by key on time this will be the most accurate way to tell true engine hours unless the ecm has been replaced.
I had my ecm hr reset on 1 of my motors to match the actual hrs when I had to replace the ecm, so anything is possible.
However, it cost a few $100 for this to be done. Your regular marina won't be able to it. They can scan the ecm, but they can't reprogram it.
If the boat looks clean, may very well be the actual hrs.
Some people are like Slinkies - Not really good for anything, but they
bring a smile to your face when pushed down the stairs.
All you need to do to change an actual hour meter is put 12 volts to it or unplug it. As said, if it is an efi, then the ecm can be scanned for the actual hours. The ECM will be accurate as long as it has not been replaced or reprogrammed.
What are the odds a 1998 boat has 78 hours? It must look like new if it does. Meters can run in reverese hooked up to 12v backwards. Or replaced. Meters mean very little to me. Condition is everything. Compression check the engine or better yet do a leakdown test which will tell you a lot more than hours.
Engine Meter
Thank You..I will find out what type of engine I have. It was a one owner so that makes me feel a little bit better. He just left the boat out in the weather with no cover.
Hour meters can be unplugged, very very easily! What about older mercruiser carbed engines? I imagine they didnt have a hour meter in the engine itself?
[QUOTE=young-gun Hour meters can be unplugged, very very easily! What about older mercruiser carbed engines? I imagine they didnt have a hour meter in the engine itself?[/QUOTE] On some merc carbed engines starting around 96/97ish you could read the hours.
1996-Up MerCruiser Thunderbolt V
Ignition module support
The scan tool supports 1996-up MerCruiser Thunderbolt V
ignition modules. Technicians can access engine operating
hour data from the module and review the number of hours
an engine has operated in several preset RPM ranges.
http://www.rinda.com/marine/mtspec.htm
