Like Tree0Likes
Does this motor look like a mag 385hp
Old 02-15-2010, 06:06 PM
Sorry I cant see a serial number and I really dont want to call the guy I was just curious. I tried to get him to e-mail better pics of the interior in the fall and he never responded. I think this guy is up to no good!
tieboy is offline
Old 02-15-2010, 06:31 PM
POWERSTROKE
My Boats: 42 fountain
310 hp
POWERSTROKE is offline
Old 02-15-2010, 10:03 PM
My Boats: 1994 32' Sunsation Dominator
Wouldn't call him dishonest right off the bat...maybe just doesn't know the difference. I've got twin 7.4's in my boat and had to actually do some poking around to find out the difference when I was buying. Give him a call and ask him...Sunny owners tend to be pretty friendly. My money is it's a 310hp/7.4...pretty standard in the Aggressors. Drive looks fine..I have showers and still get the chalky buildup in Lake Erie. Boat should do upper 60's if stock.
Ryan8886 is offline
Old 02-15-2010, 10:45 PM
rush's Avatar
Default This should help
http://sunsationboats.com/articles/1996%20March.pdf
rush is offline
Old 02-16-2010, 01:59 AM
My Boats: .......32............. ...............Active Thunder....
Quote:
Originally Posted by Unitek View Post
could be a really old school 385 mag
No, it could not be. As stated, its a 7.4 which is rated at 310hp and its not a magnum engine. 454 Magnums will say "454 Magnum" on the cowl. The only way its a 454 mag is if the cowl was replaced.
No 454 mags with that cowl were 385hp ever. If it were a magnum engine with that type of cowl, it would be a carbed engine and would be 365hp.
Griff is offline
Old 02-16-2010, 05:38 AM
BURNSMAZZ's Avatar
My Boats: 1998 BAJA 33 OUTLAW 13ft Whaler with a 40
Could be 330 hp
BURNSMAZZ is offline
Old 02-16-2010, 06:00 AM
SeaDated's Avatar
My Boats: 2004 38 Fountain Lightning
It is not a 385 Mag!!
SeaDated is offline
Old 02-16-2010, 11:03 AM
My Boats: 1988 Sea Ray Pachanga 27
I say 310 to 330 max. Still a nice boat!!
pachanga27 is offline
Old 02-16-2010, 12:14 PM
Quote:
He responded quick to me read below.
All I have right now is the hull ID number if that will tell you then fine otherwise. The boat is covered with this 22 degree weather I have right now I wont be able to get them back on. No motor work has been done to this boat. SP325144K596. Sunsation confirmed that this is a 454 mag last summer when he discussed prop changes. Currently is running the original stock 25 3 blade which is a good indicator that this is a 385HP engine. Most boats in other brands of this size run a 23 3 blade stock.
Old 02-16-2010, 01:11 PM
Lots of boats with 7.4's and 454mags use the same prop. The magnum engine boats, just spin at 400rpms higher.
It is definately not a 385hp 454 mag. They were all EFI/MPI and did not have plastic cowl cover. It could be a carbed 454 mag/365hp, if and only if, the plastic cowl was maybe broken and replaced with a 7.4 cover.
Griff is offline
