what to do?????
Old 04-19-2002, 04:41 PM
Breathe Later's Avatar
Default what to do?????
How bad is this??
Breathe Later is offline
Old 04-19-2002, 04:42 PM
Angry more>>>>>>
what about this? Any suggestions? POS merc risers leaked
Old 04-19-2002, 04:50 PM
Pantera1's Avatar
Default Flushem
I would never buy cast merc mani's again.. Bite the bullet and get some GILs or something.
Pantera1 is offline
Old 04-19-2002, 05:14 PM
Cattitude's Avatar
Unhappy Interesting dilemma
So how many hours or seasons should one expect out of the factory merc manifolds on a BBC.
fresh water only?
Salt but flushed religously?
Salt and lazy about flushing?
Cattitude is offline
Old 04-19-2002, 05:56 PM
fresh water only, 3 seasons, stored indoors, heated warehouse.
My biggest concern is damage to motor. Will do compression check and leakdown. The worst rust was beneath cyl 3 as it is inline with opening in riser. The risers only have about 3/32" sealing area on the inside between the water ports and the exhaust port. Piss poor design IMHO.
This is reminiscent of the space shuttle's solid rocket booster "field joint" that catastrophically failed.
Looking at CMI's.
Old 04-19-2002, 06:26 PM
Pantera1's Avatar
Default Oilit
Id soak that valve stem and the top of the cylinder with mystery oil to help it free up the rust..Worse than rust if you ran it with water in the cylinder you might have damaged the wrist pin or rod bearing from hydraulic lock ..Good luck
Pantera1 is offline
