-   -   496 Impeller Housing Kit (https://www.offshoreonly.com/forums/general-boating-discussion/226131-496-impeller-housing-kit.html)
30 outlaw 2005 03-11-2010 09:48 AM
I know some one makes the kit for the 496 Impeller housing that has the stainless steel end plates to help prevent wear. I have search for 3 days and can't find it anywhere. Help.....
hp500efi 03-11-2010 12:26 PM
try R & R Products (928) 453-6411
I think that is the place...hope they are still around
30 outlaw 2005 03-11-2010 02:41 PM
I had thought there was a web site. for this product. Not sure if that is the same place. Called and got a machine. Anyone else???
hp500efi 03-11-2010 03:47 PM
Your right, they had a website with pictures however I looked like you did and found nothing. Wondering, maybe they closed down?
Baja_Bigdog 03-11-2010 05:02 PM
I had saved several links for impellers....but can't seem to find them now. Here's is one....will keep looking.
http://www.dougrussell.com/partscata...,100,210,60,50
http://www.mercruiserparts.com/mercruiser_parts.asp
Baja_Bigdog 03-11-2010 05:58 PM
Just found this....
http://www.diamondperformanceparts.c...cat=250&page=5
http://www.diamondperformanceparts.c...roductid=17065
Not sure what this fits....but it is sweet.....
http://www.diamondperformanceparts.c...roductid=17066
Finally a Sea Water Pump repair kit designed to do the job once and for all and will last a lifetime. An all new 316L stainless steel water pump impeller housing to replace the cheap factory plastic style housings used on original equipment applications. These impeller housings won't corrode, erode, or crack and fall apart like original equipment units.
The one piece rear impeller housing features a unique rear housing that has 1" NPT female inlet/outlet ports so that a wide range of fitting and hose connections can be used for ease of installation.
If your looking to do this job once and for all this could possible be the last sea water pump repair kit you ever buy look no further as this is the finest direct replacement sea pump repair kit on the market today.
The kit includes:
O-rings
Impeller
Stainless Wear Plate
Polished Stainless Steel Sea Pump Body
Bolts, Nuts & Washers
This kit replaces:
Jabsco – 43210-0001
Quicksilver – 46-72744-A32
Mercruiser – 46-807151-A2
Mercury – 46-807151-A8
Mercury – 46-807151-A9
Quantity 1000 item(s) available
Weight 4.00 lbs
Price: $165.00
Too lazy to check right now....but this would be nice for my 496Ho's if it fit.
GO4BROKE 03-11-2010 06:25 PM
I was told that won't fit.
R andR has the only good fix I could find. Nice to deal with once you get a hold of Randy. Cheaper and more permenant than replacing with another stock pump that will wear again. Easy to install.
BL6 03-11-2010 07:10 PM
I bot from place out in Havasu a couple yrs ago, maybe R&R was name? Worked very well.
30 outlaw 2005 03-12-2010 10:25 AM
The one from Diamond will not work. I have the two air lines to drain the system. The only one I could use it the factory one. Anyone know of a place that stocked this kit ither then R&R?
boatnt 03-12-2010 06:16 PM
Grand Sport Center is now selling the kits
