-   -   prop slip question (https://www.offshoreonly.com/forums/general-boating-discussion/231242-prop-slip-question.html)
hawk232 05-24-2010 09:04 PM
prop slip question
what are normal numbers for prop slip on a setup like mine? 1986 formula f3ls, zz4 crate motor, 21p mirage. According to my calculations it looks like about 7% which seems crazy to me. I am used to light outboards where my 29p @ 9.5% slip is pretty good, so it just doesnt seem right that a 4k lb boat can have LESS slip!?!?!
tcuda499 05-24-2010 09:25 PM
we need your numbers.... pitch,rpm,speed,gear ratio
hawk232 05-24-2010 09:58 PM
21", 45-4600, 57-58mph, gear ration I am not sure of. its an alpha one, seem to have read somewhere its either 1.47 or 1.50
throttleup 05-25-2010 07:44 AM
Are your speeds GPS and is your tach accurate (86 would be an old tach to be using without vertification)?
Julie
hawk232 05-25-2010 08:47 PM
no verification on the tach, it may or may not be original, i know its not new lol speeds are gps
hawk232 05-25-2010 08:48 PM
i know how to calculate slip btw. i just want to know what a normal accepted range is. i have a small out board boat that is pretty well setup, so i know all about prop slip in that setting
Griff 05-26-2010 08:50 AM
7% slip in an older single engine straight hull is highly unlikely. I think you need to verify the tach and gear ratio in the drive.
