Vacuflush pump keeps running >
Old 06-15-2010, 12:41 PM
Rob
Strip Poker 388's Avatar
Originally Posted by PWRQUEST
The boat is a 2002. The toilet flushes great. bowl valve, where is that? Yes I would like the guys number. Thanks for all your help...
bottom of the bowl,when ya push the lever it rotates to open,looks like pac man open
ill look for the #
Strip Poker 388 is offline
Old 06-15-2010, 01:00 PM
PhantomChaos's Avatar
Don't they call that the ball-cock valve?
PhantomChaos is offline
Old 06-15-2010, 04:47 PM
Rob
i have a few #'s in my notes
VHT
Dometic
AER supply 1800-767 7606 Philip,in Texas
1866 636 7723
281-474 3276
2002 receipt said
vacuum relief valve 385310627
uniseal 600343023
Nort mine has a sealand ceramic potty, not sure on the terminology? its says ball,shaft kit and the seal says rubber and Teflon seal kit for it.
New one
http://www.sealandtechnology.com/pro...ges.asp?pid=23
parts list
http://www.sealandtechnology.com/pdf...317769012).pdf
manual
http://www.sealandtechnology.com/pdf...T%20Manual.pdf
hope this helps
Rob
http://www.sealandtechnology.com/pro...ges.asp?pid=46
test http://www.sealandtechnology.com/pdf...t%20342275.pdf
Old 06-15-2010, 04:49 PM
Ball- cock...... Ball shaft.... What are you guys trying to order???
jeff1000man is offline
Old 06-15-2010, 05:02 PM
Rob
Nort started the potty mouth talk
Old 03-17-2013, 07:02 PM
Default Older Vacuflush
Does anyone know anything about the older Vacuflush system, 1985 40' Searay. Pump keeps running but has a lot of vacuum when flushed. Tank is separate from the in line pump. Thanks, Lou
lou911sc is offline
