Octane rating in Marinas?
I know there are experts on here so I have some questions. Can you find 91 Octane readily available in most marinas in Florida? How about Grand Bahama? Is there a online directory that shows where these marinas are? Thanks.
I'm not certain about elsewhere in the state, but I can tell you that 91 is becoming a real rarity on the water in the greater Tampa Bay area. I only know of one place near me out of dozens that still sells 91. It used to be plentiful, but not anymore. Also of note, of the handful of waterside fueling docks I've been to in the Cape Coral area, I have not seen anything above 89.
I have recently tested over 40 samples of pump gas from off the street stations, from 7-11 to Exxon. In each case here in Virginia the gas was said to contain 10% ethanol.
Each sample gasoline regardless of rated octane contained 9-11 % ethanol Each sample was 1 to 1.7 points higher in octane that what the octane rating was on the pump ( these are also the "minimum octane" as the sticker on the pump says) 89 octane for example is really 90 - 90.7 octane |
Originally Posted by CigDaze
(Post 3139372)
Around the corner, at the new hotel AND up the river at the wharf. My engines require it. |
| All times are GMT -5. The time now is 11:18 PM. |
