27 Glasstream is running bow down and slow I could uses help
I have a 27 glasstream I bought through insurance it was completely stripped origanally had 1 engine. I have rebuilt boat with two 250 efi Yamahas and can only get it up to 58 mph at 5400. I have put nose cones on it with low water pick ups and manual jack plates. I am running 25 miriage props with a countrer. I am not sure what side the counter should be on I have tried it both ways to try and get bow lift I am not sure about what style of prop I should run or what heigth I sould be. I here of big mph numbers out of these boats but I am not even in the ball park.
Spin the props in for bow lift, maybe 4 blades?
Try corking the front live well. It will fill and not drain. Is it a scx or ccx? Also that boat loves bravos or power tec 4 blades.
It is a scx will 4 blade give me bow lift?
Usually they offer stern lift. That boat just loves 4 blades for some reason. Never had any luck with 3 blades on that boat at all.
What pitch should I start with?
those motors turn around 5750 or so. i wold see if i could try a 24 or 26. you might call power tec and see what they recomend. Also either size bravo. try and find a dealer with blue ones. They are the loaners.
I was on one last weekend w/ 225 optis, I think he is getting close mid to upper 70's the thing takes off like a rocket. definitely running 4 blades not sure on the pitch, it's a light boat and it was rough so we took a beating
this was an 04 scx |
Pete280 Any issues with the o4 boat ? I'm interested in the boat, but not many made so information is scketchy
I thought it was a decent boat, definitely not made for rough water, we came back from the eastern shore in honest 3-4's and it was brutal. If you up on the James or somewhere protected I think it's a good boat. With 225's it flew,
btw, it seemed to run flat to bow down, but that was probably due to the seas |
Try a pair of 25* pitch Rev4's from Mercury.
BBlades sent us some for our 32 Glasstream and it became a rrocket and very stable with a slight nose up attitude. |
What kind of speed were you getting? What motors were you running?
The 32 had 275 Verados and we were in the 72-75 range depending on water and load.
Step bottoms love the REV4's these were far better than any other 4blades we used. |
Is any one running jack plates or you just bolted straight on the transom? Top hole?
2 Attachment(s)
Originally Posted by Pete280
(Post 3144524)
What position are you on the transom are you running jack plates?
No jack plates. 2nd hole down from the top on the opti's and the verado's.
i guess that was his dreamometer, I did notice this weekend they were 24p 4 blades,
(Post 3145132)
btw, it seemed to run flat to bow down, but that was probably due to the seas Did the one you rode in just have the power heads replaced? |
