-   -   Help..timing not advancing on HP500 EFI (https://www.offshoreonly.com/forums/general-boating-discussion/23340-help-timing-not-advancing-hp500-efi.html)
fastedy 04-30-2002 09:42 AM
I should have posted this before Daytona.
Problem
3000 to around 4000rpms 26.17 degrees
then jumps to 28.22 at 4000 and sets there until 5050 rpms
then it will fully advance, it's my understanding full advance should be reached by 3500 at the latest.
DDT (scan tool) shows no codes or previous codes,
changed ECM's no change
replaced knock sensor, changed fules, changed filters
I get different answers from everyone I talk to from thats the way it works to turn the distributor. Joey Impressa said change
IC module, plan to do that this weekend, any input would be helpful.
Thanks in advance,
Eddie Simmons
Superboatusa.com f1-68
fastedy 05-01-2002 02:49 PM
to the top
TYPHOON 05-01-2002 09:05 PM
Eddy your timing was right, you made the race in Daytona.You need help catching me.
PS I have a spare motor if you want to try it. call me.
Randy
fastedy 05-06-2002 09:09 AM
last time, to the top
