1 Attachment(s)
We used a hair dryer and then wipe the boat down with Goo Gone to get the stickie stuff off...I works Great!!!!
called a paint supply house today and they recommended two products:
1. Woodgrain and Stripe remover 2. Astro 400E Wheel. I'm buying both because I'm finally getting around to removing 12 year old vinyl off my aluminum trailer. I've tried heat, ez-off, cussing and nothing is touching this stuff. Will let you know how it goes. |
Great ideas. I was gonna say Goof-Off and possibly Acetone (fiberglass cleaner/prep). Works good on rub rails and tar-like scuff marks around the hull...
Rick |
Goo Gone works wonders- especially on racing decals... and it comes in a spray bottle form also
Lysol disenfectant spray work very good.
I use the 3m wheel it works great.
Peel off the vinyl decal as much as possible. A new single edge razor blade works well. Then use acetone or Goo Gone to remove the left over adhesive. Neither one will harm the gel coat. Rewax after the use of either one.
Originally posted by mike merola I use the 3m wheel it works great. |
no i do not have a part #
it cost about 70.00 for it you`ll love it . it works great mike |
Re: decal removal ?
I used the 3m wheel, it was awesome and cost about 14.00.
Make sure you use the right drill, I was going to fast first. Curtis |
| All times are GMT -5. The time now is 06:19 AM. |
