Originally Posted by ILMORdude
(Post 3167181)
Thats transmission loss. Total loss with drive is around 30hp
UD If you want to make thje trek to the east coast I'll give you a ride, maybe even let you drive! I'm as anxious as anyone to experience the difference in performance & handling. The part I dread is starting all over from a prop testing standpoint especially when they are 2x+ as much. Hope my fellow boaters & Skater can get me close b/c once I pick the boat up from Skater my propeller inventory for testing will be gone. |
4 Attachment(s)
A few pics of the tedius work that goes into mocking up the engine & drive in order to get the proper driveline angle & alignment resulting in the fabbing up of new motor mounts
Originally Posted by NASCAT
(Post 3167354)
How does that compare w/ the total loss hooked up to a bravo style Teague or IMCO? Do you have any such data??
UD If you want to make thje trek to the east coast I'll give you a ride, maybe even let you drive! I'm as anxious as anyone to experience the difference in performance & handling. The part I dread is starting all over from a prop testing standpoint especially when they are 2x+ as much. Hope my fellow boaters & Skater can get me close b/c once I pick the boat up from Skater my propeller inventory for testing will be gone. I saw a comprehensive breakdown that used a dyno to spin a series of drives and backcompute the loss. - I'm looking for it. Im pretty lucky - for a nominal fee Teague shows up with a truck full of props at the lake Uncle Dave |
Originally Posted by Uncle Dave
(Post 3167414)
Searching...the last number I read was 55HP @ 5500 it was more at 6K.
Im pretty lucky - for a nominal fee Teague shows up with a truck full of props at the lake Uncle Dave Sounds like you have awesome resources when it comes to prop resources. |
Cool upgrade! Congrats.
(Post 3167422)
I was hoping IlmorDude would have some test data w/ regard to h.p. loss thru a bravo style drive w/ Ilmor angine in front of it.
Comparing parasitic drag in a Bravo setup to parasitic drag in an Indy (or NXT or #6) setup would be interesting, but not necessarily relevant. The Bravo package has nowhere near the torque capacity of the Indy. A more relevant comparison would be between the Indy, the NXT and the #6 packages, including transmissions.
NASCAT - Good luck with the process. Your photos remind me of where I was with my 725/Indy installation back in April! At least I didn't have the rear engine mount/drive coupler installation issue; my package installion was very straightforward. |
Originally Posted by C_Spray
(Post 3167742)
NASCAT - Good luck with the process. Your photos remind me of where I was with my 725/Indy installation back in April! At least I didn't have the rear engine mount/drive coupler installation issue; my package installion was very straightforward. I don't know that I can say your custom install was easier but I think you were more so starting w/ a clean sheet of paper once you filled in all your stringer & transom holes. I haven't received / posted any of the reworked hatch scoops pics that was required for header clearance yet but that should shed some light on the domino effect of engine relocation in order to achieve the proper driveline angle! So yes I agree a retro fit like mine involves a different set of hurdles & then we can multipy those hurdles x2 engines! |
(Post 3167742)
NASCAT - Good luck with the process. Your photos remind me of where I was with my 725/Indy installation back in April! At least I didn't have the rear engine mount/drive coupler installation issue; my package installion was very straightforward. Its relevant in that every HP you deliver to the water means something. To date almost all Ilmor packages are packaged with Bravos- "recovering" lost power and gaining reliability are both selling points IMO. UD |
(Post 3167845)
..I haven't received / posted any of the reworked hatch scoops pics that was required for header clearance yet but that should shed some light on the domino effect of engine relocation in order to achieve the proper driveline angle!...
| All times are GMT -5. The time now is 05:51 PM. |
