-   -   Stern Lifing Prop (https://www.offshoreonly.com/forums/general-boating-discussion/235707-stern-lifing-prop.html)
JBoat 07-28-2010 01:48 PM
Stern Lifing Prop
Question on a stern lifting prop.
I have been running a Bravo 1 24p for some time now and just moved to a 23p Hydromotive quad IV, which everyone I talk refers to as more of stern lifting prop.
My question is with a stern lifting prop will it put a higher load on the drive if is lifting the boat higher. Right now I have a bravo 1 and 575 ponies so I have been trying to baby the drive and don’t want to put the added stress on it if that is the case.
GLH 07-28-2010 05:52 PM
Man if I had my notes from Tres Martin's course I could tell you right away but I will have to check them and try to answer later, specially on a V-Hull.
onesickpantera 07-28-2010 05:56 PM
Man that is a good question I never thought about that! I would ASSUME it doesn't as the stress is on the gears from moving the boat forward. But that is just a guess.
Try posting it the prop section and Brett or Julie will probably chime in.
JRider 07-28-2010 06:05 PM
I would say less load due the lower pitch. If the boat runs with less wetted surface there will also be less load on the gears. If the prop is lifting the stern there may be more load on lower bearings. With 575 HP i wouldn't be too concerned.
Tres 07-29-2010 07:31 AM
It will not do anything to the drive. The transom lift from that prop will only be felt to a small degree. Drive just transfers power to the water. Only if the diameter is alot bigger it will load the drive more on accel and deaccel.
AIR TIME 07-29-2010 08:29 AM
the stren lifting props seem to work good on cats and stepped hulls. if you boat has a deep drive 6'' or more the stern might put your bow down making you trim more and getting a loose felling or walk more at top end. if it is deep a rev 4 by merc with a 25 might be faster than the b1 and it has a small dia, I know it works well on deep drives. good luck.
onesickpantera 07-29-2010 09:45 AM
I agree my boat LOVES the Rev4!
JBoat 07-29-2010 05:00 PM
I have run the rev 4 on a test prop before and the difference was ever so slight. I went from the bravo1 24p to a rev4 23p and it basically ran the same.
Going to run the hydo this weekend and see what it does, seems like the drive is going to be just as safe either way.
onesickpantera 07-29-2010 05:28 PM
Yep I would try the Hydro. Never pass up a chance to try a prop!
On my boat the handling between the Bravo and Rev was night and day in sloppy water.
