Dyno vid-straight down the barrel >
Old 08-12-2010, 07:57 PM
Default Dyno vid-straight down the barrel
Here's a dyno vid of a 502 Mag MPI with a 2.3 L Whipple, looking right down the throttle body. I ditched the stock Mag throttle body in favor of a 2000 cfm piece. The stocker is a major restriction for making power with these. It also got a cam change, extrude honed intake, conversion rocker studs and roller rockers, Mefi 4 ecm and harness, and a set of Cometic head gaskets. Everything else is bone stock. It was actually running out of ignition right at 5000 rpm because of the stock 10 yr old plug wires and coil I wish I would have had more time to get a set of wires and a coil on it because with the cam and the extrude honing it should have pulled to about 54-5500 rpm. I really think it would have made close to 800 hp. It made a best of 754 hp and 841 ft lbs of torque, missing it's azz off over 5K rpm. It should be a BUNCH of fun in a 25' Baja. Enjoy. Thanks for looking.
By the way.....check out the 2-80# injectors just under the throttle body. At lower rpms you can see them pulsing, but as it reaches 5000 rpm, they almost look like they are on all the time since they are pulsing so fast.
Here are the links to the vids:
http://www.youtube.com/watch?v=wubuyaEcTBc
http://www.youtube.com/watch?v=bZcBU7vclYU
Eddie
Young Performance is offline
Old 08-12-2010, 10:42 PM
SORE MEMBER
Wobble's Avatar
Very Nice
Wobble is offline
Old 08-13-2010, 07:47 AM
Ted G's Avatar
Do the 2 injectors just supplement the stock injectors?
www.cbpba.com
Ted G is offline
Old 08-13-2010, 08:35 AM
KiloKat
KiloKat's Avatar
Here's a dyno pull of one of my alky motors ...
http://www.youtube.com/watch?v=bxhlw9wDZ_4
Everything Runs Better On Alcohol
www.nautiboats.com
KiloKat is offline
Old 08-13-2010, 08:55 AM
dykstra's Avatar
God D.mn, That sounds awesome!! Is that in a residential garage? If so, that makes it even cooler! Good luck in the shootout.
Dave
dykstra is offline
Old 08-13-2010, 09:45 AM
how bout this in the driveway
http://www.youtube.com/watch?v=tVTO82Wg3as
mike11 is offline
Old 08-13-2010, 10:03 AM
dykstra's Avatar
AWESOME!!
dykstra is offline
Old 08-13-2010, 10:04 AM
dykstra's Avatar
Sorry to hijack thread Eddie, now back on topic!
dykstra is offline
Old 08-13-2010, 10:10 AM
No sweat brother. I don't mind at all when we are looking at horsepower. Post away.
Eddie
Old 08-13-2010, 10:19 AM
Yes. The stock injectors are 42 lb's. They are only good to about 650 hp, tops. The Whipple kit has a provision for the extra 2 injectors, but they are smaller than the 80#'s I put in.
Eddie
