grider hill on cumberland
heading there in 2 weekends and cant find it on the dashboard gps. does anyone know a chain stoor or something that will show up within 5 to 10 mi from the marina. i got the address on mapquest just trying to make it easy.
Not sure what would show up on the GPS, but it's not too difficult to find. My brother tried to use a GPS and wound up way lost. If you come down 127 across the dam, it's pretty easy. If i recall there were signs marking the way from 127. We did it in the dark, boat in tow with no problems.
FYI If you are planning on towing your 38 to Grider be careful around the marina. I ended up infront of the lodge with the rig, and there is not an easy place to turn around. Be sure to follow the signs to the ramp. It is quite steep and twisty once you get on the property. Enjoy it! |
brians fever
Are you going to be there for the poker run? |
im going to be there on the 27t , 28th, and 29th. i think the poker run in sept.never ben there before plus we are still dialing in the new power packages maybe poker run next year.
Good luck with dialing in. Hope to see you next year.
| All times are GMT -5. The time now is 08:53 AM. |
