Like Tree0Likes
SHOGREN Performance Marine Winterization Tips
Old 09-28-2010, 10:41 AM
In addition (if you don't mind) if you are using a Weldon Pump and can separate from the fuel system. Three good "squirts" of Marvel Mystery" into the inlet of the pump, cycle for a second or two and cap pump off with protective AN caps. Also keep fuel lines capped with the proper AN plug or cap.
If you cannot split from system easily, make sure that you've got enough of a good fuel stabilizer / mositure inhibiter to prevent the pump's internals from rust and corrosion. We use no plastics or phenolics inside of our pumps -- only tool steel.
Start the next boating season off with new fuel filters (water separator / filter & secondary fuel filter).
thanks
Jim Craig is offline
Old 09-28-2010, 01:31 PM
DriverofDonzi
DriverofDonzi's Avatar
My Boats: 14' Searayder 1996 (recently sold)
If you own jet boat...it is very easy to fog engine, stabilize in the gas tank and winterize your jet boat for winter.
Chris
DriverofDonzi is offline
Old 09-28-2010, 01:49 PM
My Boats: 40 SKATER
Quote:
Originally Posted by wellcrafted View Post
150 gallon tank 3/4 full 112 gallons that sit 6-7 months in boat octane goes from 91 to 80 with water in it and in the spring running 112 gallons of wiesel fuel through a 500 + HP motor I can see problems waiting to happen with the shi$$y fuel in it . No way would i do it runem empty and put 150 fresh gallons in it in the spring.
No way would i do it , runem empty and put 150 fresh gallons in it in the spring
+ 1
Old 09-28-2010, 01:57 PM
My Boats: Velocity 2008 290 600 SCI , whipple stage 2 kit. Sea Ray 1989 Sorrento S-19
Quote:
+ 1
Thank You RHR No other way to do it.
wellcrafted is offline
Old 09-28-2010, 02:52 PM
My Boats: Donzi 22 Classic
Race fuel wont break down like gasoline or 10%ethanol mix. You can put that in the tanks for long-term storage.
Planetwarmer is offline
Old 09-28-2010, 04:06 PM
My Boats: 1995 Baja Outlaw SST 454 Mag
I left my tank full last season and delt water issues all summer this season....never again. Its going away empty this year!
Z06 FAN is offline
Old 09-29-2010, 06:45 AM
blownincome's Avatar
My Boats: 2003 35 Executioner
Quote:
Originally Posted by Expensive Date View Post
Run mine to almost empty with stabil and startron added at the last fillup.
have done this since the intro of E10 no issues !
blownincome is offline
Old 09-29-2010, 10:28 AM
My Boats: 85 Baja Force 320
I leave about a 1/3 tank in mine with stable in it over the winter. In the spring I fill it and add Toluene. Never had an issue.
I agree with the rest though. I wouldn't want 3/4 of a tank of old fuel in my boat to start the season.
wjb21ndtown is offline
