Anyone have pics of a carbon fiber vinyl interior?
Originally Posted by cigrocket
(Post 3234540)
I always had great dealings with Miami Corp. I got my carbon vinyl for my mini boat from them XT |
could you post a link to the heater elements... i can't seem to find them
i have used Morbern and have been very happy with it
1 Attachment(s)
Originally Posted by bigboat28
(Post 3234570)
Originally Posted by XT-Innovator
(Post 3234571)
I see they carry carbon fiber options from both Enduratex, and Morbern. From my direct experience with Enduratex while working for Baja Marine is that they started with a great product, then they moved the supply source to Tiland, and the product was never as good. Stick with the "Shock" series from Morbern, or G&T (Spradling Internationals) "Carbona" series carbon vinyls. For a really nice result, make sure it is laminated with 1/4" foam backing (1.7) density the way we stock it.
XT |
Originally Posted by Jassman
(Post 3234597)
can you possibly give some real world test of time on these CF interiors. The ones that I have looked at with some age were dirty in between the CF pleats, and over time when cleaning they rubbed out, and this was from 2 different manufactures..Love the way they look, just wanting them to last... thanks for the help. Jeff
All vinyl testing for Baja Marine was done by Sea Ray, and I better not post any documents owned by them. The test boats at Baja never lasted more than a year, but the carbon vinyls we used held up well, and passed the SR testing. Here are some stadards, and terms to look for in testing of vinyl products: REFERENCE DOCUMENTS: • ASTM (American Society for Testing and Materials)standards: See table 1 • AATCC (American Association of Textile Chemists and Colorists) standard: 147-1998(99) • SAE (Society of Automotive Engineers) standard: J855-1994 • Federal standards: 191-5304, 191-5651.1, 191-5874 • CFFA (Chemical fabrics and Films Association): Standard Test Methods, Glossary of terms for the Chemical Fabrics and Film Industry • CIE ( International Commission on Illumination) : S001/ ISO IS 10526 Colorimetric illuminants, S002/ISO IS 10527 Colorimetric observers DEFINITIONS: Abrasion - Measurement of the ability of the chemical coating to resist surface wear when rubbed against another (abradent) surface. Adhesion – A measure of the force required to separate a chemical coating from the base substrate. Bacterial Resistance – A determination of Bacteriostatic activity of chemical coated fabrics. Blocking – Unintentional adhesion between plastic films, or between a film, and another surface. Colorfastness to light – A determination of the resistance of chemical coated fabrics to exposure to laboratory simulated sunlight. Color variation - Total amount of color change (listed as E in tables 2 and 3) between master and sample being tested. (DE=[(L)2+(A)2+(B)2 ] in the CIELab system) Crocking – A measure of resistance to transfer of color from a chemical coating to another surface (usually a fabric) by rubbing action. Fabric – Refers to the textile material used to enhance the physicals of the composite formed by the coating/lamination of the plastics to the textile. The fabric usually is in a woven, knitted, or non-woven construction. Woven fabrics consist of fabric formed on a loom with two separate yarns (warp and filling) that are at right angles to each other. The two yarns go over and under each other in a designated pattern. Knitted Fabrics are formed by a single, or multiple yarns, making interlocking loops. Non woven fabrics are formed by laying a continuos web of random spaced fibers to form a uniform batting. The fibers are then bonded to form a fabric by chemical adhesion, thermal or chemical processes. Flex - A determination of the change in surface appearance of a chemical coated fabric when subjected to multiple flexing. Low Temperature Resistance – The measurement of the ability of a chemical coated fabric to withstand cracking at low temperature. Mildew Resistance – A determination of the ability of a chemical coated fabric to resist fungal growth. Tear Strength – A measurement of the force required to continue or propagate a tear in a coated fabric. Tensile strength – A measurement of the force required to break a coated fabric. Volatility – A measurement of Volatile weight loss of a chemical coated fabric when subjected to an elevated temperature. |
I was looking for a whole interior pic done in the carbon vinyl. Mine is going to be yellow just cant decide what to do.
Originally Posted by mptrimshop
(Post 3234574)
http://www.sportsimportsltd.com/carb...oem-specs.html They were on the front page, but moved for some reason. If you click the original link and sort by price/highest, they pop right up. There are also smaller elements for $79. I personally think it would be sweet to install 8 of these in two rows of four right across the sunpad. I could sleep like a baby under the stars with a toasty back and a light blanket! :coolcowboy: |
Ohh, OK. I like mine so far. Just apply conditioner/protectant before you use the boat!
http://img697.imageshack.us/img697/8...03170bd.th.jpg http://img840.imageshack.us/img840/2...c03169g.th.jpg |
| All times are GMT -5. The time now is 11:46 AM. |
