Steel bunks insted wood...:eek:
Originally Posted by Oh Deere
(Post 3241508)
Rich |
One of my lifts has more wood than it should on the bunks and it floated so I took a 3 foot long 4 inch PVC pipe capped one end filled it with concrete capped the other end and hung it on the lift. Problem solved
Let the air out of the tires... problem solved!
It is one of the true advantages of having a tandem/ large cap axle trailer over a triple, along with paying less for tolls, getting better gas mileage..etc.
Originally Posted by Chart
(Post 3241489)
I was about to suggest strapping water tank to the trailer for weight, but the add extra psi to the tires for weight is a better idea.... :)
See my posts from the other linked thread. My techniques worked. Also, make sure you pop a hole in the top of the fenders. They trap air and also become buoyant. |
Originally Posted by Sydwayz
(Post 3242041)
This won't work. It will only add weight when the trailer is on land, not underwater.
Originally Posted by flyinlow
(Post 3242079)
By his post it was obvious he was joking
Originally Posted by txriverrat2001
(Post 3241802)
| All times are GMT -5. The time now is 05:56 AM. |
