-   -   Thoughts on giggle gas (https://www.offshoreonly.com/forums/general-boating-discussion/242036-thoughts-giggle-gas.html)
orthos1 11-08-2010 05:22 PM
It works for drag boats but not offshores due to prop problem and eating engines and drives. I think if you could bring it in gradually (there are systems that do that) and you are sane about its use it could work but eventually it will eat parts.
4mulafastech 11-09-2010 09:14 AM
Originally Posted by Griff (Post 3249023)
You really can't prop a boat correctly to run NOS.
Sure you can. Hate to disagree with you Griff, but I know first hand at least on my application it worked great.
Off the bottle my engines turned 7800-8000rpm and performed great. On the bottle they turned 8600-8800rpm. Same props. It just added to the acceleration and top speed. These engines really came to life on the juice! Reliable too. Only failure in 5 seasons I had was a broken prop shaft when punching off around 50mph on the bottle. With no load on the engine it instantly wound-up to around 10,000rpm and took out the upper crank bearing.
BLee 11-09-2010 09:26 AM
There was a guy on our lake years ago that had NOS on his 272 Formula. The button was right on the throttle arm.
He was always having problems with blowing drives, & not being able to put the power to the prop efficiently. This was back in the late 1980's, and he said 75mph was the best he could ever get it to run, WHEN he could stay on the bottle long enough. http://smiliesftw.com/x/nos_smile.gif
