-   -   why doesnt most cats have trim tabs? (https://www.offshoreonly.com/forums/general-boating-discussion/242125-why-doesnt-most-cats-have-trim-tabs.html)
Outkast Rafe 11-08-2010 10:10 AM
Ted G 11-08-2010 10:12 AM
By nature cats tend to run flat from side to side because of the air cushion in the tunnel, and the tabs typically won't have near the effect on angle of attack that a tunnel tab will for that same reason. So if they need trim that the drives can't provide a tunnel tab makes more sense.
glassdave 11-08-2010 10:52 AM
Yep. . . . . . What Ted said. We have them on the race boat and I have never used them once. Tunnel tab comes in handy once in a while though.
antisocial 11-08-2010 10:55 AM
They dont need trims but if you dont have one in the tunnel good luck gettin on plane....
Outkast Rafe 11-08-2010 11:18 AM
i see
thanks
stainless 11-08-2010 12:08 PM
Not all cats need or would benefit from a tunnel tab.
Mine gets on plane just fine without a tunnel tab.
I do use my trim tabs a small amount in rougher conditions
Outkast Rafe 11-08-2010 12:20 PM
what is tunnel tabs? any pics?
paul buckner 11-08-2010 12:24 PM
i think it is a large tab between the 2 hulls ?? paul
Too Stroked 11-08-2010 12:31 PM
A Tunnel Tab looks like a giant Trim Tab mounted at the rear of the tunnel between the sponsons. It re-directs air more so than water because of it's location. Drop it down and you pack more air in the tunnel - which gives you more lift. On a center pod tunnel (Eliminator cats for instance), it works more like a single Trim Tab.
Outkast Rafe 11-08-2010 12:36 PM
oh yes ive seen one of these before on a American Offshore i think
