Originally Posted by RunninHotRacing158
(Post 3253337)
+1 and i fixxed her for ya :lolhit:
good luck & see ya on the Lake Todd:drink::drink::drink: |
I was planning on going with the Brad Penn for sure... even though I am running a roller cam now and don't necessarly need to run the high zinc but figured it couldnt hurt.
The 100mph run is very doable I think... just need to get another set of props. Running bravo 32's merc lab finish, but hitting 5500 rpm at 94mph. Thinking of trying another set of 34's and sending those out for labbing. Tried a stock set over the summer but couldn't plane out. Needed more cupping. |
(Post 3253337)
good luck & see ya on the Lake Todd:drink::drink::drink: Also, just food for thought, our 8.1 GMC lost 10lbs oil pressure when we switched to Brad Penn from Mobil 1 silver cap. After 1k miles, we put silver cap back in, and the oil pressure is back to where it was before the brad penn. I know alot of circle track and drag race people run Brad Penn, but the lower oil pressure deal in our truck kinda scared us. |
So you added a hyd roller cam, lifters, stock heads setup by Jim Valako and a little bit of his magic. NICE!!
Originally Posted by saxman
(Post 3253507)
I'm with ya. The oil that Kendall was "famous" for is now Brad Penn. The Kendall name was bought and now a lower grade oil is produced under that name..... the newer Kendall hasn't been very popular to say the least. I think this happened in the late 90's or so.
Also, just food for thought, our 8.1 GMC lost 10lbs oil pressure when we switched to Brad Penn from Mobil 1 silver cap. After 1k miles, we put silver cap back in, and the oil pressure is back to where it was before the brad penn. I know alot of circle track and drag race people run Brad Penn, but the lower oil pressure deal in our truck kinda scared us. Todd just curious why did'nt you guys put a new set of rings in while you had her all apart ??? just thinkin cheap insurance .. good luck BIG Daddy |
I thought about it but when we did the leak down tests, the percentages were very low so I let it go. I ask myself the same question but the overall goal was to hit key west this february and I knew I would not have enough time to break in the motors prior to then if I put new rings in. We are hoping to get a trip in to the Bahamas from the Keys if all goes well....
