Okay to run engines off flat hoses? >
Old 05-13-2002, 12:25 AM
CBR
www.hyperfishing.com
CBR's Avatar
Default Okay to run engines off flat hoses?
Okay I have some nice new flat, easy coil hoses but I am very nervous about flushing the engines via perko flush kits with them, as I am worried the thin walls of the hoses may be sucked together. Hence, I have not done so. Anyone have any experience with this?
CBR is offline
Old 05-13-2002, 05:01 AM
mcollinstn's Avatar
I have no experience with them, but can't you flush with the kits without running the motors?
mcollinstn is offline
Old 05-13-2002, 06:20 PM
I have done it - You should not have a problem. The pressure from most hose outlets should more than offset the draw of your engines. The water will keep flowing.
Run a test with the engines at idle. Once the engine fires up feel the hose, there should still be pressure in it.
The only time you would have a problem would be with a low pressure/low flow hose outlet. (You would also have a problem with a regular hose in that situation.)
stevel is offline
Old 05-15-2002, 02:11 AM
CBR
CBR's Avatar
Great Stevel that is the answer I was seeking! Many thanks!
CBR is offline
BajaRunner
26
06-07-2005 07:15 PM
boatman747
04-20-2005 08:58 AM
fred
10
05-17-2002 12:17 PM
Quick Reply: Okay to run engines off flat hoses?
