Originally Posted by lightning jet
(Post 3263654)
On the carb motors I have used ATF for years poor it right down the carb till it smokes out the exhaust
Ditto :drink::drink::drink: |
Originally Posted by Sydwayz
(Post 3263617)
1) Dump 1/2 of fuel water separator out and fill with 2-stroke oil, re-install and winterize with this mixture. OR 2) Run fuel line to fuel pump from small can of gasoline with 2-stroke oil premixed...... |
I've used ATF for years with no issues. Actually burns off nice.
I pour Marvels Mystery oil right down the carb. Been doing it for years. It does not foul the plugs. :)
1400 hours on a set of efi 502s in a sportfish. Never fogged them, turn them over every 4 weeks or so in the winter as the boats up on the hard. Fire up in April every year and go boating. I have more worries about the ethanol than the fogging but lucky so far.
atf
If the boat is shrink wrapped Fog it!! (since you built a greenhouse/terrarium) if indoor stored heated not necessary but optional...indoor stored not heated (like mine) I fog it to be safe.why not..
I always used the crc fogging oil.But this year I used atf and it seemed to be okay.
Originally Posted by Griff
(Post 3263793)
I also use my boats often enough that keeping the cylinders coated with oil isn't an issue:coolcowboy:.......unlike some trailer queens:party-smiley-004:
I have a feeling Audiofns Formula still has the fogging oil from some 10 yrs ago. :D |
Correct Packer- no MAF on my EFIs : ) I put sea foam in a spray bottle and choke those *****es until Spring, then I replace the fuel filters in the spring before I run it - I also use a gas stabizer Seafoam loves keeping moisture out of fuel too - so its two fold
http://www.seafoamsales.com/how-to-u...treatment.html 20 years of Auto Repair haven't failed me to date |
