-   -   Tinkerboater (https://www.offshoreonly.com/forums/general-boating-discussion/24379-tinkerboater.html)
BGIII 05-14-2002 06:21 PM
Tinkerboater
Machine work is done, planning on picking up parts Wednesday around 4:30. When might I be able to talk you into massaging the block? Where do you want to work on it, my place or yours? I am in Hudsonville near 48th & Port Sheldon. Crazyhorse has an old headgasket for us to use. What else do I need? Thanks
Tinkerer 05-14-2002 11:03 PM
Lets try for thursday night. Do you have an air compressor that will run a die grinder? Air compressor and the old head gasket is all that we will need. I do have an electric tool but it is not as easy to use as a die grinder.
BGIII 05-14-2002 11:22 PM
Picking up a compressor tommorrow, not real big but it should do the trick. I'll call you tommorrow, I have to juggle my schedule around a bit. Thanks
