Like Tree0Likes
Hydraulic Steering Add-on
Old 12-13-2010, 08:12 PM
Trade Score: (1)
scottw's Avatar
My Boats: Switzer 250SS
Default Hydraulic Steering Add-on
Looking install a add-on kit to my boat over the winter. Single drive dual ram. What system is good to add so I can upgrade to full hydraulic next winter. Best bang for the buck...
scottw is offline
Old 12-13-2010, 09:22 PM
AT Cult Member #3
R Addiction's Avatar
My Boats: '99 Active Thunder Tantrum
Quote:
Imco
R Addiction is offline
Old 12-14-2010, 01:07 PM
Only the Best Will Do!
KEPP's Avatar
Well of course were partial but we do sell all of the brands Mayfair, Zeiger, Imco, etc. I do think if value, quality, and ease of installation are your desire then you just can't beat the Mayfair system. Whether it's the polished stainless steel modular wingplate that not only attaches through the back cap and to the outdrive mounting studs(Not just an aluminum end cap that requires drilling into your outdrive like other brands. Also voids all Mercury warranty when you do that). To highly polished large diameter stainless rams, one piece SS Thru hulls and true 316 braided stainless steel hydraulic lines. But take a look and compare for yourself we would be glad to assist you. NOTE* The Mayfair and Zeiger kits are sold complete while the Imco kits still require an additional hook up kit #421-HK11 for $140.00
http://www.keitheickert.com/p-11553-...ering-kit.aspx
http://www.keitheickert.com/c-868-imco-marine.aspx
http://www.keitheickert.com/p-12360-...ng-system.aspx
Happy Holidays
KEPP is offline
Old 12-14-2010, 01:52 PM
My Boats: 1987 Donzi 22; 2008 Donzi 28 ZXO
how fast is your boat? for single engine with reasonable speeds I'd suggest doing single ram full hydro now instead of the upgrade to full later. The price of doing the half system then upgrading is a killer Vs. buying it all up front. If it is installed right, the singe ram is more than enough for most performance boaters. If it is a cat hull that is running triple digits two rams is better, but other regular performance boats two rams are unnecessary.
VetteLT193 is offline
Old 12-14-2010, 02:10 PM
Trade Score: (5)
My Boats: 22 Donzi Classic 525 EFI
I went with Zeiger dual ram since they make a kit ready to install on my boat and they supply the OEM kits to Donzi. Customer service is top notch. Make sure you get a helm that won't give you too many turns of the wheel.
thirdchildhood is offline
Old 12-14-2010, 03:12 PM
if I remember correctly, the larger the cc capacity of the helm, the faster it is and fewer turns lock-to-lock
have an understanding (even if I'm remembering this concept backwards) of this and have it be a part of your purchasing decision
that Switzer is a pad bottom isn't it?
you want a fast helm, so lesser wheel-wiggle will keep it on the pad at speed
Rippem is offline
Old 12-14-2010, 08:19 PM
AT Cult Member #3
I take it you don't like the Imco systems KEPP, then why do you sell it?
Scott, I installed the twin ram add-on system to my boat then two years later went to full hydraulic. The price difference by going 1/2 then 1/2 was minimal. Just my two cents. Call me if you want to get some prices together. (I know people)
Old 12-14-2010, 08:32 PM
Trade Score: (1)
scottw's Avatar
That sounds good John.. I'll be in touch.
scottw is offline
Old 12-14-2010, 08:41 PM
My Boats: 98 ActiveThunder Tantrum
I can't speak for other systems, but put the Mayfair on my Baja before I sold it. It was very simple with the Instructions. But more importantly, the Modular Wing Plate looks BadA$$ on the drive.
My Addiction is offline
