Like Tree0Likes
Bracing of tail pipes on stagger setup
Old 12-15-2010, 01:38 PM
Default Bracing of tail pipes on stagger setup
i have a staggered motor setup. On my forward motor, i have the long tail pipes that connect to the header collector and run to the rear of the boat. The length of these tail pipes are about 4 1/2 ft, with one having a dogleg. Currently, my tail pipes are not braced, but i want to brace them both to the rear of the motor, preferably having the brace connected close to the collector/tailpipe connection.
Has anyone already done this and how is the brace connected to the tailpipe or collector?
IlmorDonzi is offline
Old 12-15-2010, 02:09 PM
Tom A.'s Avatar
My Boats: Necessary Evil .............Donzi 38 ZrComp.............
Good question, I was thinking about some sort of bracing as well.
Tom A. is offline
Old 12-15-2010, 02:43 PM
My Boats: 38 fountain lightning 700,s 6,s
get ahold of eddie young, he has done them in the past !
575cat is offline
Old 12-15-2010, 05:14 PM
Just Milkin' It
Kelly O's Avatar
My Boats: 2012 MTI 36RP; 09 35 Fountain Lightning, sold
My 35 Fountain staggered has a saddle for the front motor's tails that is simply a 1/2" stainless rod bolted to a stringer at bottom and welded to a cradle at top. Stainless clamps around the pipes hold them down into the cradle.
Kelly O is offline
Old 12-15-2010, 07:54 PM
Trade Score: (7)
eddie's Avatar
My Boats: What ever they let me us
Quote:
My 47 is the same, but the rods are bolted to the bellhousing.
eddie is offline
Old 12-15-2010, 11:52 PM
Here are some pics of one I did. The tails on the front engine are almost 8' long and weigh a TON.
It is a ring cut from aluminum, split in the middle and drilled and tapped so that it can be bolted together. The supports are SS bar stock with threaded bungs welded on the ends. They are adjusted and attached using RH and LH heim joints.
Eddie
Bracing of tail pipes on stagger setup-skater-399-rigging-018-large-.jpg   Bracing of tail pipes on stagger setup-skater-399-rigging-017-large-.jpg   Bracing of tail pipes on stagger setup-skater-399-rigging-019-large-.jpg
Young Performance is offline
Old 12-16-2010, 08:51 AM
Quote:
It is a ring cut from aluminum, split in the middle and drilled and tapped so that it can be bolted together. The supports are SS bar stock with threaded bungs welded on the ends. They are adjusted and attached using RH and LH hiem joints.
Eddie
Nice looking work! I need to have that done on my Gladiator.
redbud35 is offline
Old 12-16-2010, 11:07 AM
Thank you. I would be glad to do it for you or help you get it done. Just give me a shout if I can help.
Eddie
