Jesel 1.70 Ratio BIG Chief rockers >
Old 01-19-2011, 02:01 PM
Default Jesel 1.70 Ratio BIG Chief rockers
Lookin for 2 sets of Jesel 1.70 Ratio BIG Chief rockers
C8MA70
CWHB70
CAAS70
i'm thinking these rockers work there azz off and the Aluminum has to Fatique ,dont feel like just having new bearings pushed easier to replace em .. who's a suppler/warehouse ????
thnx
Old 01-19-2011, 02:52 PM
SS930's Avatar
Slightly OT, but have you had any issues with valves dropping with those Big Chief heads?
SS930 is offline
Old 01-19-2011, 03:05 PM
here are few dealers in your area
book racing 815-464-7200
a-team speed 708-633-1320
midwest engine tech 815-464-9490
fx engines 708-479-0900
or call direct 732-901-1800
panicrev is offline
Old 01-19-2011, 03:14 PM
nope !!!!!!!!!!!!!!!! just dont be cheap BIG Daddy and be sure to use the 1 piece Titanium valves like Mike D. does & not the friction welded ones ..
Old 01-19-2011, 04:48 PM
Default Fixx
Im not knocking jessel's but have you considered switching to a TD rocker?? WE use both on the race cars and the TD's last twice as long as the jessel..jessel uses a sealed bearing which fatigues after hard use..The td's uses the engines oil which in return lasts a whole lot longer..If you dont have a whole lot of oil going to your top end than stick with the jessel's..
http://www.tdmach.com/
FIXX is offline
Old 01-19-2011, 05:05 PM
have'nt heard alot about the TDs , waiting on a call back about Harlan Sharp 1.70s ... we do have oilers up top BIG Daddy
thnx
Old 01-19-2011, 05:15 PM
You're right about the fatigue. Aluminum has a finite cycle value before they go pop! Might be time to go steel. Bob Madara has gotten me great pricing on T&D stuff and he is an absolute guru on valvetrain stability. Give him a call 585-654-8583
HaxbySpeed is offline
Old 01-19-2011, 06:05 PM
thnx HAX i'm dialing him up right now ...
Old 01-19-2011, 06:42 PM
T and d are the best. Spend the extra you'll love them
mr buttonhead is offline
Old 01-19-2011, 08:03 PM
New Steel T&D's seem to be the best. Upgrade to spring oiler in the rocker.
SkiDoc is offline
