gph conversions etc.?
I was told as a general rule for EFI engines, divide the HP by 12-12.5 for gallons per hour at WOT. Carbed engines are not quite as efficient so divide the HP by 11.5-12.
So a single 500 EFI with 470/12 = 39.1 gph at WOT and Two 500 EFI with 470x2/12 = 78.33 gph at WOT ...just asking but would two engines be more efficient, therefore burning less gph? ...and is there a way to figure mpg at cruise? |
Dude really?? C'mon w/ all these questions... Your basicslly asking the same things over & over!!! Your that worried about efficiency your looking into the wrong hobby.
454/502 blocks, N/A....figure 1 mpg with twins, 2 mpg with a single. It should be a little better but for budgeting that will be close....and I agree, gas will be the cheapest thing you spend on a boat. If those numbers scare you, look for one with a sail on top.
Gas, insurance will cost as much maintenance or vice versa as t500 said. And I mean maintenance that keeps it in top shape (no failures when taking it out) My numbers are .8-1.7 mpg twin 454 mags. About $400 a day in fuel. There is a passion for these boats that negates cost.
I would be more concerned about coming up with an average GPH figure. Or, GPH at certain RPMs.
As far as MPG, that depends on the hull. I could squeeze around 4 MPG @ 55 MPH from my last boat w/496. |
For my first poker run in the Spectre, I had my friend with me that's a CPA. At lunch he mentioned that before the day was over we would have spent $500 on gas and oil. I told him that was the cheapest thing that could happen to us that day.:drink:
Originally Posted by jmoore1225
(Post 3334694)
If the checkbook was unlimited I wouldn't be asking these questions and just write a check for a few million... |
I run twin 540ci n/a motors,I would say at 50mph I burn about 15 to 20 gal per motor about 3400-3600 rpm as said before gas is the cheapest part of these boats my 2 cents
YOu can make the tank last a month or you can burn it in a DAY1 Its your choice on how much you use it.
GPH come on. The conditions vary way to much and the throttle position is what matters the most. |
It varies by boat. I get better mileage with my 32 AT with twin 502mpi's than I did with my 28 Pantera with a hopped up 525SC.
That is at cruise speeds only. WOT, the AT uses more fuel. |
| All times are GMT -5. The time now is 03:48 PM. |
