Control cables for Scarab Sport 302 - HELP
I have a 2000 Scarab Sport 302 that I want to replace the throttle / shifter cables.
Anyone know how long they are? I looked all over the cables I have and there are no markings. Also, the cables currently installed are for OMC Evinrude. I am putting new shifters that mate to the 33c cables, but looks like I need an adapter kit to allow the 33c to work with the OMC engine. What kit do I need? I've replaced control cables on quite a few boats before, but no outboards. Slightly intimidated on trying to run cables thru the big tube from the transom to motor. Any tips??? Thanks in advance! http://www.seriousoffshore.com/forum...0&d=1282998891 |
Mine are 22'. Under my console, the cables go forward and then loop back into the bilge opening. My motors are also set back 28" from the transom.
Since we're on the subject of SS's, I have a question about mine. The fishbox all of a sudden is filling up with water on its own. I only use it for storage and the pumpout has been disconnected for years. I have to pump it out manually every 10 days or so. It doesn't appear to be rain water getting in their. When I use a garden hose to see if the boat is draining properly, everything seems normal. All the water seems to be going around the hatch and into the bilge like normal. Is this a common problem with SS's ? Any help would be appreciated. The first 6 years I've had the boat it never happened. Thanks in advance
Your boat may be setup differently than mine. Where is this fishbox located in the boat?
Originally Posted by STV_Keith
(Post 3337043)
Scarabs are usually marked behind or under the dash panels near the indicators if you have them.
Originally Posted by frankenstein
(Post 3337055)
It's in the floor. Between the drivers bolster and the rear bench seat
(Post 3337503)
Hmm, I don't have that box...my fuel tank is down there.
water in live well
(Post 3337026)
hope this help some way mine is a 2000 302, having issues with the FITCH'es now and bad fuel, these are original engines from Wellcraft. Nelson |
| All times are GMT -5. The time now is 09:01 AM. |
