oil coolers.
where are yours mounted?
bell housing. under motor. remote (on a stringer) |
anyone?
1 Attachment(s)
Over the bell housing. 3x18
i have #6 bellhousings,the coolers are part of the bellhousing.
i have these monsters. and i have had them mounted on bell- housing but makes it so tight back there. i wanted to mount them under the motor somewhere or on a stringer but don't want the bilge to look cluttered. looking for suggestions.
http://www.eddiemarine.com/store/car...l&p=13576&c=47 |
they have some stringer brackets available but dont look to strong.
I have a similar cooler from Mr.Kool. I mounted mine on the stringer with the brackets. They have been holding up fine.
I mounted the brackets/cooler when the motor was out though. |
mine are out rite now too... getting ready to put them in so wanted to figure out where i should put them... i want the bilge to look as clean as possible.
Originally Posted by STRAIGHTPRIORITY
(Post 3339973)
I trimmed a little out of my motor mountswelded a half of a piece of stainless tubing ( cut lengthways) and welded it to the inside of the mount with braces. These were 3x18 and essentially were right behind the alternator along the side of the block.
to secure them i used stainless hose clamps with a piece of rubber between them and the tubing. As Mike said above this way when you pull the engine everything is self contained, and very secure. Dave |
that is exactly what i want under the motor hidden and comes out with the motor. i know i have seen it but wasn't sure the best way to do it. thanks for the input guys.
u wouldn't have any pictures that show it do you?
i will look, my puter with all my pics is in the shop so i may have to wait until it comes baclk next week.
sounds good i appreciate the help.
sorry i don't have any pics o f the set up -- i need to start taking more of everything---
just be sure to mock it up with everything in place to make sure that your hoses have enough room for clearance -- the less fittings the better... |
| All times are GMT -5. The time now is 05:40 PM. |
