Like Tree0Likes
Engine Oil Pre - Lube Systems
Old 03-19-2011, 05:47 PM
My Boats: 27 Fountain Fever - 540 c.i. Custom built by Rudy Dryden
Great idea! I'm going to look into adding one.
VetteSteve is offline
Old 03-19-2011, 06:02 PM
My Boats: 40 SKATER
Quote:
Cool , let me know what ya find
are you boating 2day ??? Rudy sayz its 75 degrees and drinks on him at the naughty [email protected]@se
Old 03-19-2011, 08:35 PM
SS930's Avatar
My Boats: 1990 Donzi Sweet 16
I've always used Accusumps in all my track cars. Never a single issue with one.
SS930 is offline
Old 03-19-2011, 08:43 PM
cougarman's Avatar
My Boats: 1986 Cougar US-1 46'
Hey Buddy,
Friend and bought ours about 12 years ago and still work great.
We went with the marine / turbo version for naturally aspirated engines and his are blower engines.
Reason for going with the marine/ turbo version is the pump runs a post cycle too,..........so you turn the key and it brings it to full pressure,......start it run it and go where ever....
Soon as you shut the engine off the post cycle automatically starts and pumps oil through all your hot bearings. You can set the computer for the post cycle with I think 3 options of how long to run on the post cycle.
Nice pump very heavy duty,........quick connect so you can drain the oil pretty fast too for normal maintance.
http://www.pre-luber.com/preluberkits.htm
Jon
cougarman is offline
Old 03-19-2011, 08:53 PM
Boat engines suffer a lot of dry starts which scuff off metal from cylinder walls and other critical areas. A preluber will extend the life of your expensive marine engine;
http://www.masterlube.net/marine.htm
Catmando is offline
Old 03-19-2011, 09:08 PM
Crazy Energy
Trade Score: (4)
Velocity Vector's Avatar
My Boats: Old Skool 35' Ocean Express Cat 1700 HP
I bought the KE Pre lubers, A little pricey $700.00 each but a good feeling when to here the pumps start bogging down when the engines are primed.
What I like the most about this system they give you a quick disconnect fittings and a extra hose to pump out the oil when you service the engines. Stick the hose in a 5 gallon bucket and flip the switch and the pump sucks it right out.
Velocity Vector is offline
Old 03-20-2011, 03:53 AM
Trade Score: (2)
My Boats: 38' Powerplay
My KE 675's have the pre-lube system installed. Flip a switch & oil pressure prior to turning the engine over. Use the same pump to change the oil!!!!!!
DEFYN GRAVITY is offline
Old 03-20-2011, 09:00 AM
My Boats: 40 SKATER
Old 03-20-2011, 09:05 AM
My Boats: 40 SKATER
Steve give Rudy a call if your adding a Luber,he's got 1 sitting on his desk 4 u
DREYDEN PERFORMANCE MARINE
302-367-4962
get that thread started on that Waukegan Ill motor that lasted less then an 1 hour
Old 03-20-2011, 10:08 AM
My Boats: 1998 Awesome 31 Thundercat
What he said. I was planning on designing/building/installing a "timer panel" for pre-post use. After seeing this product, why re-invent the wheel? Nice find guys, thank you.
http://www.pre-luber.com/Images/12v_ecm.jpg
ROTAX454 is offline
