Originally Posted by mikes280
(Post 3359935)
nice project , have you called casale and talked to them , i used to talk to Andy out there but it has been years and he was older so i am not sure if he is still around.
The V drive it's self is not an issue. How to install it is.:drink: |
Originally Posted by f_inscreenname
(Post 3359939)
I would install it as setup A.
Setup A has a more equal balance of power going to the drive/prop. Whenever you have a multi-motor, single drive configuration, IMO the best thing you can do is rule out variables and try to keep things as balanced as possible. |
You say you have the original Casale 1000. How is it set up?
If the v-drive is not 1:1 ratio then you have to go with figure A. 1 LH and 1 RH rotation engine. If it is 1:1 you could go either way however with figure B you could use engines of the same rotation. IMO figure A would be stronger with the 2 engines being splined together turning the shaft through the gear in the same direction. Figure B I would think jerking back and forth on the teeth would result in a broken tooth especially if a engine hic-uped. |
(Post 3359944)
they may can help with that , i have put them in normal v-drive set ups but not anything like this
This question is for me and just would like to hear what everyone else thinks. |
(Post 3359872)
Have the original Casale 1000 (only about 40 made), 1.09 to 1. A B/W Velvet drive, 1 to 1 on each motor.
As I said I don't want to get into all the logistics until I get a consensus on how folks would do it if it was theirs. I will be more then very happy to discuss it all then. I have enjoyed following your project on your web page. :drink: |
Originally Posted by picklenjim
(Post 3359951)
If the v-drive is not 1:1 ratio then you have to go with figure A. 1 LH and 1 RH rotation engine. If it is 1:1 you could go either way however with figure B you could use engines of the same rotation. IMO figure A would be stronger with the 2 engines being splined together turning the shaft through the gear in the same direction. Figure B I would think jerking back and forth on the teeth would result in a broken tooth especially if a engine hic-uped. I have the original V Drive and know exactly how it was set up but......... Getting ready to put it together but running a theory by everyone to see if my theory is insane or not. |
This will F_ with you all.
http://www.supernova19.com/26646650.jpg This boat's set up is picture B. How many times did this boat win the championship? |
(Post 3359958)
http://www.supernova19.com/26646650.jpg This boat's set up is picture B. How many times did this boat win the championship? I geuss that would keep the gear slap down as one engine would be pushing or geting pulled ,how ever you want to look at it. Very cool project thanks for sharing. |
(Post 3359958)
| All times are GMT -5. The time now is 03:18 PM. |
