Like Tree0Likes
More prop selection questions
Old 04-10-2011, 08:58 AM
My Boats: 42' Sundancer from 2004 formerly known as Big azz cruiser from 2004. Still looking for the right new 38-42 ft. v-bottom!
Quote:
Originally Posted by pitts1313 View Post
I believe a stock 7.4 330hp should operate at about 4600 rpm. A mirage plus will carry the bow higher than just a mirage.
You are correct. 4200-4600. I don't remember when the rev limiter kicks in. I did not see the engine was posted in post 4. Doh!!
I'd wote for a 21"M+ being the right prop for that boat. Get Bblades to lab it to 22". Then it would fly
A.O. Razor is offline
Old 04-10-2011, 09:49 AM
AIR TIME's Avatar
My Boats: BAJA OL 650HP/ SABER 28 Gellner unlimited with konrad ace
when I bought mine it was set up with 330hp, I ran the mirage 23 at 4600. bret could lab it for you. that s a m plus. your x is deep. gps could be 60 to 62. my best was after 5 motor builds ending with 650hp 509 and mid 80s with a 2''imco shortie. that was over 19 years of changing set ups on the boat. once you add a shortie you need a b1 prop.
AIR TIME is offline
Old 04-10-2011, 11:51 AM
Quote:
Those are pretty cool numbers.
The reason for me thinking the 21" would work well, is because my experience tells me, the M+ hits lower rpm's than the original Mirage.
