Class V Hitch
I just replaced the factory hitch on my F-350 with a Reese Titan Class V. The problem is I can't find anybody who stocks or can order a locking pin for this hitch because it is 1/2 " bigger than the standard hitch. Does anybody know who makes a locking pin for a class V?:confused:
I didn't know that. I just ordered my Titan class 5. I'll let you know if they have the locking pins. I have one for my Class 4 I guess I can't use anymore:mad:
The biggest one I could find (even from Reese) was for a class 4. It might come down to having something fabricated. Are you also getting the 2.5" hitch, or are you going to use the sleeve adapter for the 2". The place that put mine on happened to have the 2.5" hitch and I am afraid it will get stolen, and I will have to order another one since nobody stocks them if that should happen.
BTW: I was also told the adapter sleeves are hard to find as well so either way you go be careful of theft. |
How about sleeving your class4 pin? I dont think strength will be a problem since some of us have been towing far over the class 4 weight with a class 4 hitch.
Reese makes one. I have it on order. I'll post the part number Tuesday Night.
Dan |
You may want to try Tractor Supply co.
I just got my Titan hitch on my new Dodge 2500. I ordered the hitch, reciever, ball and whatever else is needed to rig this truck to tow 12000!! It was complete and ready to roll when I picked it up. Call the Hitchman 301-870-0290. They can hook you up!!
Steve:) |
Who did you purchase the hitch from ? If they carry Reese hitches they have access to the draw bar, hitch balls and draw bar pins required for the Titan line.
If the pin was not included or they do not know where to get one, I would also make sure the hitch ball is capable of handling the 12,000lbs dead weight load. I am only making this suggestion because the person who sold you the hitch did not have the pin and does not know where to get one may not know where to get, or about, the high capacity ball. Good luck:D |
pin
call south fla trailers (954)966-0580 ask for jay or email and will send it cod to you mer 1200 @ gte .net:D
Thanks for the suggestions, I will give them a try. Just so everybody understands I did get a pin with the hitch, but it is not a locking pin, and I also got the 12,000# ball. I was told that they checked the Reese catalog and they did not carry a locking pin for the class V, just class 4 and below(they may not know what they are talking about). Thanks again.
Chris:cool: |
My Titan V didn't come in yet.:mad:
I ordered it a week ago last Thursday and they said it would be in Monday. I guess I should have asked them which week. I would sure hope that someone would carry a locking pin for these things since they are definitely the most expensive.:eek: I asked for one and they said no problem. These are they same people that said it would be in on Monday.:rolleyes: patience...patience... __________________________________________ Rule #1 Never pray to God for patience. He will reward you with many opportunities to practice. |
Sorry:rolleyes: I misunderstood what you said. You did say locking pin, as in anti-theft. I would suggest drilling out the current pin and using a pad lock if you cannot find one commercially available. You do not want to simply machine an existing pin or fabricate your own unless you know the specs and can properely heat treat the pin. Case hardness and depth is important when it comes to impact strength, wear and shear capability.
There is new style locking pin with a "U" on one end and a lock on the other. It requires 2 holes ...1 for the pin and 1 for the other end of the "U" ...and what this does is keep the little movement we all get in the draw bar and receiver. You now the "clunking" at red lights or stopping and pulling out...the one that makes you slow up and think "What the hell is that noise"
If your receiver does not have 2 holes...I just drilled another ...only on one side..because I always put my lock on the port side of the hitch...because of the brake socket. Call "Back East Acessories: 724-863-7000 ask for Joe This is in no way an advertisement.....that's where I know you can get them Yes for Class V Titans |
If you have to wait awhile for a locking pin I would use a grade 8 bolt in a pinch. I have a lot of customers that use this instead of a lock. They usually double nut them and never take them out though. Would work good in a pinch if you can't find one quickly.
Buck #183 |
buck183, I would not try this.:( Use the pin that came with the hitch until you can get a good locking pin. Grade 8 bolts are great for bolted joints when the joint carries a portion of the load. By themselves they do not have the shear capacity. Think of your lug nuts, when they are tight, they will carry a tremendous load, if the joint is loose a 30 mph panic stop can shear them off.
Obviously everyone has an opinion, and I respect that, but I would not do this with a 12,000# load (which probably cost $xxx,xxx.xx).:D |
I have never personally done this myself. Although I have customers that haul Cattle and Equipment in excess of some of the loads we are carrying in our boats that do it all the time. Seems kind of hick to me, but I would think it would work in a pinch.
Buck #183 |
Reese makes a lock for the Titan. I am picking mine up on Tuesday from the dealer. I had to call Reese because the item wasn't listed in the catalog. I’ll post the number for you.
Dan |
The Reese part number is 74172. It is a standard 5/8" pin. Fulton is the manufacturer name stamped on the piece.
Dan |
| All times are GMT -5. The time now is 03:50 PM. |
