Like Tree0Likes
Mounting Tape That Sticks To Fiberglass?
Old 05-08-2011, 09:13 AM
My Boats: 13' Biel Tunnel Hull / 23' Fountain CC
Quote:
Originally Posted by HTRDLNCN View Post
Here in the Texas heat were it regularly hits 100+ in the summer any type of tape will melt right off the fiberglass regardless how well you clean it or sand it.Its resin or 5200 if you want it to last.
My transducer module which weighs a few pounds is mounted inside my console and a vertical wall with 4 one inch squares of 3M dual Lock. The boat gets beat up pretty bad on rough days fishing offshore and temps inside the console are over 140 degrees when its in the Florida sun with the full black cover over the boat. Its been mounted there for 5 years now and never come loose yet removable if I need to service it. We used to use the same stuff to mount MSD boxes on race bikes for ease of swapping parts. I have never had the stuff fail and the adhesive side is very strong.
Mr. Demeanor is offline
Old 05-08-2011, 09:18 PM
My Boats: 32 Skater
I agree on the 42 or 5200 as for it getting on the lights, just tape the lights up first then apply, stick em, then after it starts to tack pull the tape...
mlb75 is offline
Old 05-09-2011, 01:13 AM
My Boats: 85 Baja Force 320
Dual sided carpet tape at Home Depot sticks to anything I've tried applying it to, and HARD. It's a mfer to get off though...
wjb21ndtown is offline
Old 05-09-2011, 11:01 AM
Trade Score: (1)
My Boats: 29 PHANTOM 36 SKATER 38 POWERQUEST
Quote:
Originally Posted by hotjava66 View Post
They are flex strip lights, very thin and flexible,
Are they exposed or tucked up out of sight? If the later, I would think you could zip-tie them like any other piece of rigging, just use the real thin ones.
fantastixvoyage is offline
Old 05-13-2011, 04:58 PM
My Boats: Saber 28
Ended up using 3m acrylic tape for trim, worked great after sanding/cleaning and using the adhesion enhancer. That stuff works wonders, I got it on my fingers while wiping it on, and if I even touched the sticky part of the tape look out.
hotjava66 is offline
Old 05-14-2011, 03:28 PM
Rob
Trade Score: (6)
Strip Poker 388's Avatar
My Boats: Hustler 388
I did apretty good bit of research when putting mirrors on the bottom of my hatch,you can not pull it off with out breaking the mirror.The tape is thicker and conforms to the rougher surfaces better..045-inch-thick black tape with red cover.
http://multimedia.3m.com/mws/mediawe...y&nocomments=y
Mounting Tape That Sticks To Fiberglass?-mirror-drive-036-large-.jpg   Mounting Tape That Sticks To Fiberglass?-hustler-boat-car-show-025-large-.jpg   Mounting Tape That Sticks To Fiberglass?-hustler-boat-car-show-026-large-.jpg
Strip Poker 388 is offline
Old 05-14-2011, 10:51 PM
Just about any 3m tape will work, the strongest is called VHB, very high bond. I used it to attach the aluminum side walls on a motorhome....it dont come loose
kinda pricey
SHAWN DAVIS is offline
