-   -   Jcperf (https://www.offshoreonly.com/forums/general-boating-discussion/253069-jcperf.html)
Mastercraft240 05-07-2011 06:00 PM
Jcperf
Turned it to 5300 with a 32P, a full tank of gas, and 3 people. Need to prop it down.Jeff can still throttle:evilb::drink:. Turn up the volume.:coolcowboy:
http://youtu.be/Fdp1bcbC6bQ?hd=1
spazboz 05-07-2011 06:14 PM
Love the sound.
Philm 05-07-2011 06:15 PM
Nice. Glad it worked out.....this time.....:drink:
sv43BB 05-07-2011 09:58 PM
Good luck. I have used jeff many times always had great results. He has a pair of my motors now.
Stormrider 05-07-2011 11:30 PM
Great 1st run.
Are you happy with the speeds?
Btw, does anyone make a bluetooth mic?
That would be slick to have it mounted to the transom.
The audio would be that much better.
PokerRun388 05-07-2011 11:45 PM
Sounds Great..!! looks like a great day too....!!
Mastercraft240 05-08-2011 12:36 AM
Originally Posted by Stormrider (Post 3397489)
Great 1st run.
We're VERY happy with the speeds. Turning a 32 B1 5300rpm, 86mph with a full tank, 3 190lbs+ people on board, and cruising at 58mph at 3900-4000rpm. With a that same load before the JCPERFORMANCE overhaul, we were only at 78mph. We've only had an increase of 30hp, but we've increased torque somewhere in the 70 range. There is a huge difference. Jeff also replaced the solid cam with a hydraulic cam which should prove to be more user friendly. Jeff has gone over and beyond with me and this motor. I can truthfully say not many engine builders are as honest, forthright, and straight forward.
SV43BB,
Saw your 1075's at the shop today. Looking forward to seeing what it'll do.
PhantomChaos 05-08-2011 01:24 AM
Sounds aweome and ran good for a couple minutes!! Not sure what you mean though about "not many engine builders are as honest, forthright, and straight forward". How many engine builders have you tried? Teague? Zul? Pfaff?
BBILL1174 05-08-2011 04:56 AM
[QUOTE=Mastercraft240;3397501] Jeff has gone over and beyond with me and this motor. I can truthfully say not many engine builders are as honest, forthright, and straight forward.
I second that he always goes above & beyond & w Zul doing the setup on the dyno Jeff is hard to beat for the price. I do think he weighs more than 190 lbs though !
dykstra 05-08-2011 05:03 AM
Sounds awesome!!
