-   -   Ground Wire Between Both Motors (https://www.offshoreonly.com/forums/general-boating-discussion/254782-ground-wire-between-both-motors.html)
Craney 05-31-2011 04:33 PM
Should you have a ground wire run between both motors grounding both motors together?
SpeedDoc 05-31-2011 04:48 PM
The battery grounds are doing the same thing. another wouldn't hurt, but probably wouldn't help either.
Steve H 06-01-2011 11:09 AM
A common ground between engines is a must. It should be the same size as your battery cable. I think that it is a CG regulation to do so. It will prevent smoking a small ground wire if you loose the main ground while cranking your engine.
Steve H 06-01-2011 11:36 AM
Found it!
http://law.justia.com/cfr/title33/33...4.9.222.5.html
C_Spray 06-02-2011 11:10 AM
If you have "1-Both-2" battery switches that allow you to power either engine with either battery, you must have a heavy-gauge ground connection between the engines to carry the starter current. That being said, some boats use a grounding/bonding plate where all the battery and engine grounds come together. That will serve the same purpose.
PhantomChaos 06-02-2011 12:56 PM
Originally Posted by Steve H (Post 3417438)
Interesting
CrownHawg 06-02-2011 01:18 PM
There's a law for this?
Steve H 06-02-2011 03:20 PM
Apparently it is a coast guard reg. Also it is common sense. As I stated in the above post you can melt a wire and potentially start a fire if a main ground is lost during cranking. I own an auto repair shop and have replaced more than one clutch cable because of the above scenario.
