-   -   4000rpm @ 60mph (https://www.offshoreonly.com/forums/general-boating-discussion/255098-4000rpm-%40-60mph.html)
Teddysfever 06-04-2011 09:38 AM
4000rpm @ 60mph
Im kind of new to things and i didnt know if this was good or not.. 4000rpm @ 60 mph with a 24p x 14 and 1.50 drive, with the trim all the way down. Ive heard of prop slip and not sure how much this one is slipping. thanks for the help
GTOFFSHORE 06-04-2011 09:52 AM
What motor? And what RPM speed do you run at nuetral and positive trim?
Teddysfever 06-04-2011 10:09 AM
454mag and havent had the chance to try playin with the trim, i was water testing in a small river since are lake is trashed
Havasu Hangin 06-04-2011 02:57 PM
Is that GPS?
ActiveFun 06-04-2011 03:03 PM
That sounds a bit of an optimistic speed at 4000 rpm with a 24p prop. Is that speed using a gps? That's what I'm doing with 30p props.
Havasu Hangin 06-04-2011 03:35 PM
I got 1% slip...lol. Better verify the speed or the tach.
FIXX 06-04-2011 03:36 PM
Fixx
ok so your new to this..in order to achieve the proper rpm's and correct top speed you will need to trim the boat out more..your best bet is to go to the fountain owners part of this forum and ask''what is the perfect trim to achieve the correct speed,,with tabs,with out tabs ..
