-   -   Oil Filter stuck Tried Everything! (https://www.offshoreonly.com/forums/general-boating-discussion/255688-oil-filter-stuck-tried-everything.html)
bert4332 06-12-2011 10:54 PM
Originally Posted by mudslide (Post 3427680)
I used a pipe wrench down by the base of the filter. It will crush a little then it should break loose. Put a pipe on the wrench if you have to. Good luck
That's what I'm going to do once I get it in the vice, if my pipe wrench is big enough, I don't have any can left, just the base plate screwed onto the adapter, on bammarine's schematic, it looks like the threaded fitting has a nut, so I just might just unscrew the fitting out of the adapter. I was stoked today too, finally a real easy oil change with the hose on the bottom of the pan, slip it through the hole and emptied right into the oil container, no more pumping it through the dipstick. But of course, Murphy's law kicking me in the nutz once again with the filter, just can't catch a break!!!
Comanche3Six 06-12-2011 10:58 PM
good luck...another if needed....
http://cgi.ebay.com/MerCruiser-454-7...item3a63814d60
bert4332 06-12-2011 11:04 PM
Originally Posted by Comanche3Six (Post 3427690)
Thanx but I don't think that's the same one for my 525.
Comanche3Six 06-12-2011 11:53 PM
Your right, it looks different on the 525.....I'm sure someone on OSO has a few extra ones. Anyway good luck with that stuck filter......it's amazing how it could be on that tight. Been there and it is aggravating!
dagah2x 06-13-2011 05:33 AM
Not sure if your adapter is the same but on my 502mpi i simply took off the oil lines then unscrewed the center piece from the bottom, Came right off. Chisel was my next option if that didnt work. Will be a little messy but should come right off.
BAJA342 06-13-2011 07:57 AM
Take a utility knife and carefully work it under the gasket. If you get half way around the filter it should be enough to break it loose.
88Fount33 06-13-2011 08:06 AM
Last year I had to use a 24" pipe wrench with a 3 ft cheater, wrench had to grip the rolled edge or flange of filter to get a somewhat good bite. Is there ANY gap between the filter flange and adapter? If so, I thought that the next time I had problems, I would get thickest shim type stock that would fit between and use it to "injure" the rubber gasket, if it would not budge with normal filter wrench pressure. Haven't tried it yet as my next oil change (rebuilt engines) comes this fall.
Comanche3Six 06-13-2011 10:09 AM
I used a small hooked pick and I pulled out small pieces of the gasket. It finally gave way.
HALLETT FAN 06-13-2011 10:36 AM
First try a quality oil filter removal wrench , if the filter starts to collapse , stop now ! go get a CHAIN wrench and apply it as close to the base as you can and away you go !
Dan Adams 06-13-2011 11:05 AM
Same trouble on my 525s. Used very large channel lock pliers, just kept crushing and twisting.
