Boat Idles Weird?
What cause the engine to idle up and down with in 200 or 300 rpms? While just floating.. any info would be great. Thanks mike
Blowers?
most likely a vacuum leak...
Possible Idle Air Control (IAC) valve defective
If we just knew what engine.... Carb or injection...IAC's are PITA's sometimes.. so are vacuum leaks... if a carbed engine the leak can be in the carb too... a real PITA to find out.
Mine did that when I had a jacked up map sensor on it. 525
its a 525 blower with 2 800s on it
Fixx
Originally Posted by rollnhrd
(Post 3450120)
Originally Posted by mrfixxall
(Post 3450186)
its called blower surge,,normal if you have alot of boost:drink:
The surge is caused by each revolution of the blower. Sometimes it can be reduced or eliminated with carb air bleed adjustments.
| All times are GMT -5. The time now is 10:32 AM. |
