Oil Pushing Up Dip Stick Tube?
LEAK DOWN TEST, my first blower motor I built was a 502, once the rings started going I was pushing oil EVERYWHERE, leakdown was 35+% and boat went maybe one mph slower, Smitty
KAP
Just a thought, an issue I had, with my Procharged 454 I was running too cool on the water temp which effects the oil temp which was way to low, this created condensation/moisture in the engine. Before I realized it the water in the oil brought the oil level up and I had oil coming out the dipstick after a hard run.
I reduced/restricted the water flow, removed the oil cooler, both of which brought oil temp up and removed the condensation problem which in turned stopped the oil out the dipstick......
