Like Tree0Likes
aeromotive fuel pump holding pressure
Old 08-23-2011, 06:08 PM
Default aeromotive fuel pump holding pressure
I have a mpi 454 with mi procharger it has the areomotive fuel system on it . When you key it the pump will biuld pressure but as soon as the pump stops the pressure drops unless the motor is running . Is this normal or am I getting air in there ?
h2xwithboost is offline
Old 08-23-2011, 07:55 PM
Trade Score: (2)
My Boats: 2003 37 Active Thunder
my holley does the same thing..
Drock78 is offline
Old 08-23-2011, 07:58 PM
My Boats: 1996 27' fountain fever Pro charged EFI 502 MAG
Are AERO pump does the same thing.
haulinit is offline
Old 08-23-2011, 08:33 PM
Thanks for the feed back
Old 08-24-2011, 04:41 PM
My Boats: 96 LipShip Gun
Quote:
I have two Bosch "044s" that required a good inline check-valve to keep pressure.. It still dies off over the period of a day, but it beats having to wait for the pump to pressure up to the rail/regulator after it was just running.
At one time, I had an A1000 that did the same and was fixed with a check. Just make sure the check is rated for the required flow.. (been there, done that, also)
VortechSS is offline
Old 08-24-2011, 08:00 PM
JasonSmith's Avatar
Yup, normal as can be if you don't have check valves.
JasonSmith is offline
