-   -   ProCharger 496 solution (https://www.offshoreonly.com/forums/general-boating-discussion/261464-procharger-496-solution.html)
Whipple Charged 08-31-2011 07:56 PM
After many request, and a patient customer, we finally are able to offer those who purchased Procharger SC systems for the 496 Magnum HO engines a proper tuning solution.
We've made a kit that comes with new injectors, PCM reflash, adjustable regulator, adapters and spacers, spark plugs and some misc. hardware. The calibration will work on 3, 5, and 7psi pulleys while 9psi will technically work, they will not live on pump gas unless running above 4000 feet. The factory guardian settings are maintained, idles at 675rpm, uses factory knock settings and runs very good (for a PC :))
