Lift motor help.
Old 10-08-2011, 10:29 AM
Ted G's Avatar
Default Lift motor help.
So one of my lift motors just hums and will not move. It turns freely by hand and is drawing around 30 amps when it hums. Could this be a capacitor issue (Does the same thing with the capacitor unplugged)? Or is the motor toast? Help a brother get a last good day of boating in please
www.cbpba.com
Ted G is offline
Old 10-08-2011, 10:56 AM
30 amps is pretty steep. You have a cap on a DC mtr?
tomcei is offline
Old 10-08-2011, 11:04 AM
CigDaze's Avatar
Sounds like you have a short, Ted. 30amps is big! Probably the only thing preventing a complete short circuit meltdown is the cap. There may be corrosion buildup somewhere in the windings causing current to take a detour and not through the whole motor. Or maybe the commutator has some junk stuck in it making it short. A good cleaning should likely fix it since current is still moving through it somehow.
CigDaze is offline
Old 10-08-2011, 12:27 PM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Just hook another boat to it and yank that baby off backwards! Put it back on the trailer and worry about the lift on a rainy day vs. a sunny one.
Sydwayz is offline
Old 10-08-2011, 08:23 PM
Geeze....I thought you were talking about a hatch lift mtr. Sorry.
If it's an AC mtr then you won't have a commutator.
Try swapping caps from the working mtr....just a thought
tomcei is offline
Old 10-09-2011, 10:08 AM
Default Humming motor
Hey it sounds like you need a $6.50 Capacitor take the old one over to WW Granger. Should fix you right up.
Kat Krazy is offline
