- - Hull cleaner? What's the best product
(https://www.offshoreonly.com/forums/general-boating-discussion/264215-hull-cleaner-whats-best-product.html)
offshoredrillin
10-18-2011 06:32 AM
FSR its a blue gel...stands for Fiberglass Stain Remover...on dry hull just put it on a brush or towel and wipe it, turns scum line White instantly.
88242LS
10-18-2011 03:30 PM
I use slimmy grimmy, works with ease and doesnt hurt me the trailer or the driveway
JTeam
10-18-2011 04:17 PM
If you like On-Off but are tired of getting Ripped-Off, go to a pool store or even Lowes and get a gallon of Muriatic Acid for $4.00 a gallon. Same stuff.
88242LS
10-18-2011 04:21 PM
Originally Posted by JTeam
(Post 3530562)
isn't on off dilluted, I'll never go back to muratic acid again
JTeam
10-18-2011 04:26 PM
Originally Posted by 88242LS
(Post 3530568)
Might be, in which case the cost gets even cheaper. Add water and now it's $2.00 per gallon. On-Off is muriatic acid.
Jluloff
10-18-2011 05:01 PM
Iron out takes the brown stain right off
Rebel_Heart
10-21-2011 12:05 AM
I spray the bottom every so often with Power One and wash off with water. Might have to do it a couple of times, but it will come white clean. Once you begin you have to do the whole bottom.
Scarab3DMC
10-21-2011 05:39 AM
sno bowl or any acid base toilet bowl cleaner, brush on , let sit 5 minutes hose off... cleans exhaust tips and outdrives too!:drink:
Vyper340
10-21-2011 06:28 AM
Originally Posted by E Colby
(Post 3529538)
On & Off is the best. Use it with a long handled brush and don't breathe in the fumes.
NO! On/Off will get it clean at the expense of the acid damage to the gel coat. It does work though...
I recommend Ring-Go and used to sell it. If you can't find it anywhere online let me know. I can probably contact my supplier and get some more cases but I have to do a large purchase since they don't sell small quantities (singe bottle).
They are 32oz. large bottles and one will last at least 3-4 years if you use it 1-2 times per year if you want a perfectly white boat all the time. I use it maybe once a season and mine is pristine. It is THE BEST product that does NOT cause damage to the gel coat and takes off water/scum stains, rust stains, etc. It will not remove growth (only a pressure washer does) but it gets virtually all stains out without removing wax or pitting. It is also the EASIEST product to use that I've ever come across after 30 years of boating/cleaning. Simply wipe on since it has the consistency of liquid soap, let sit 5-10 minutes and then spray off. DONE.
It doesn't get any easier than that! On/Off can't compete and I have used them all. Do a search for Ring-Go here cause I have sold it to hundreds of OSO'ers over the years.
PS - if memory serves I think I used to charge $15 plus shipping ($5-$7 UPS) a few years ago when I last did it. I don't make any real money at it and when I exhausted my cases that were required to get from the manufacturer I stopped. I was just doing it to help out OSO'ers who needed the best product.
Audiofn
10-21-2011 06:47 AM
Originally Posted by Perfect Storm
(Post 3529793)
Fountain of Youth Power One is the best hull cleaner I ever tried...
I agree. Not only does it work well but it seems to keep the hull cleaner afteer you apply it. Their other products only seem to be so so but the power one is amazing stuff! Plus if you get on off on a galvy or allum trailer it makes a mess! I got some of the Power One on my trailer and it just made that area shiny! :D
