Prop info
Old 10-26-2011, 09:09 AM
Prop info
Hey guys I have a Baja 275 w/496ho I currently have a 21p revolution 4 prop that was on the boat when I bought it. The pitch is to low I'm spiking 5500 rpms. I went on mercurys prop selector and they recommended 3 props a bravo 1 22p, a rev 4 23p, and a mirage 23p. What prop do u think will give me the most speed/ best performance I hear the 4 blades have better hole shot and handling but that the mirage is usually about 2 mph faster top speed. My boat currently runs 61 on gps at 5400rpms would love to see 65 maybe 66 if possible and get the rpms down to 5000 where they should be. Any input is greatly appreciated
Joel_Baja275 is offline
Old 10-26-2011, 12:09 PM
mirage 23 no doubt..........
offshore420 is offline
Old 10-26-2011, 03:12 PM
That's what I'm leaning towards the more research I do. I'm your opinion would getting it labbed be worth it?
Old 10-26-2011, 03:16 PM
no!
Old 10-26-2011, 03:33 PM
That's what I'm leaning towards the more research I do. In your opinion would getting it labbed be worth it?
Well Baja's have shown to like labbed props, but it can be a bit of a crashoot. As I've posted in the prop section, there has been good results from both Powerboat and Boattest.com on the 26OL with labbed 23"'s running 67 and 66,2 mph. Just be aware that labbing decreases the strength of your prop alot. Halfing the thickness of the blade only leaves 10-15% of the original strenght. Be prepared to repair and change props more often if going labbed.
BTW. Not trying to be unfriendly here at all. But you don't need to post the same question in three different forums. Take it easy, you'll get an answer.
A.O. Razor is offline
Old 10-26-2011, 07:13 PM
ha thanks a lot razor. i did all this earlier off an i phone and was a little excited and wasnt sure if it was postings because i had poor service. but thanks again on the prop info it is appreciated
Old 10-26-2011, 08:53 PM
racinfever's Avatar
496ho Rev limit is 5050 which = 60 mph
racinfever is offline
Old 10-27-2011, 09:09 AM
Yea it would go to 5400 and the alarm would start beeping....def not good
Old 10-27-2011, 03:36 PM
I've never been at the limiter in our Sea Ray cruiser, but they are not at 5050, we run between 5000-5075 depending on load. 5150 is where my manual says they will kick in, if I remember correctly. 4950-5050 is where the 496HO's likes to run. Ours are the Horizon inboard motors, but same difference.
Old 10-27-2011, 06:36 PM
Yea that's the range I'm def shooting for what size is your sea ray my dad has a 34 they are really sweet boats!!
