-   -   Rear Seat re-build (https://www.offshoreonly.com/forums/general-boating-discussion/265295-rear-seat-re-build.html)
brivander 11-06-2011 06:41 PM
Originally Posted by 97FASTech (Post 3543766)
If your going to use plywood, use exterior grade. The glue will hold up better to the elements.That's if you don't use marine grade. I used 1/2' treated plywood on my sun pad, maybe over kill, but no more rot the last few inches when the drain gets plugged.
I'm going to use marine grade, found a place local for $78/ sheet for 3/4 and $58/sheet for 1/2 (a little more than double the price of treated plywood here locally). I'm going to do the back of the seat in 3/4 and the rest in 1/2, this saves ~60lbs over what is currently there (plus the additional weight of the water logged wood that's there, not much, but it's something.
Rrice 11-08-2011 09:10 AM
I use 1/2 treated plywood, glassed it all , resin is cheap. light and I wont have to touch it again
glassdave 11-08-2011 09:51 AM
Don't use treated in marine applications especially if you plan to coat with resin, use a good marine ply. The best way to apply resin is to do a hot coat, let that cure then apply another coat with a waxing agent. I go a bit further with my stuff and fully encapsulate the structure with ounce and a half mat. The biggest problem is the edges where the wood can breathe and open up the surface coat.
Chico&Zeus 11-08-2011 10:09 AM
I used King Star-Light to re-do my seat and engine cover/hatch. Stuff is flexible, takes staples, will last forever and I paid $86 per sheet locally in Phoenix.
