-   -   Heads Up Mechanical Trim/Drive Indicators (https://www.offshoreonly.com/forums/general-boating-discussion/266888-heads-up-mechanical-trim-drive-indicators.html)
242LS 12-07-2011 02:25 PM
1 Attachment(s)
Is Stainless Marine the only manufacturer?
Why are they so expensive???
Any used ones for sale? ...or trade for some Hydromotive props (http://www.offshoreonly.com/forums/s...v-22p-l-r.html)?
Here's what I found for prices on the Stainless Marine "4 track" (trim & drives):
CP Performance: $759.99
Diamond Performance: $799.00
Stainless Marine: $849.00
Monster Marine: $1149.00
I want to make room on my dash panel to flush mount the Garmin.
audacity 12-07-2011 03:11 PM
SS marine requires a lot of room under them too! more than on top! If these are not mounted at eye level or higher...as in sit down boat. they are a waste of money because you will not utilize their accuracy. SSM also make a LED in dash set too which i have rigged with in the past and loved because the LED jumps out at you and they work in extreme sunlight and at night time.
Livorsi Marine are great for 99% of all applications! even race!
RunninHotRacing163.1 12-07-2011 03:28 PM
C.P. will do ya better then that , work em for your OSO discount :drink:
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!:coolcowboy:
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!:drink:
Rottiguy 12-07-2011 05:08 PM
I just bought a set for my boat because I wanted to add a garmin too. Expensive I know but I think its worth it, they look great
242LS 12-07-2011 05:22 PM
Cool - were you able to use your existing cables or did you need to re-cable everything?
Rottiguy 12-07-2011 05:32 PM
I used the cables I had. Make sure you have plenty of room under your dash, they are very long
Pokher Ace 12-07-2011 06:38 PM
How long? Pic?
audacity 12-07-2011 06:49 PM
make sure you tell them at SSM (wherever you're buying them) what cables you have. they have different adaptors from their cables. using teleflex morse cables requires a bunch more room at the bottom and to make the turn. SSM cables are more like a bicycle cable and can turn a bit sharper too.
Rottiguy 12-07-2011 06:53 PM
1 Attachment(s)
Here ya go
no issues 12-07-2011 08:24 PM
2 Attachment(s)
You can build it up a bit if you need to make room or bring it to more of an eye level. I attached a couple pics of the Apache so you can see what I am talking about. They are worth the money...very easy to read... you can stripe them for indicating dead level just like on the laydown surface indicators.
KEVLARKAT32 12-07-2011 08:32 PM
That price for a 4 track is just the dash unit , ad 279 per for actuators , tru hull fittings and 3.99 per ft cable over 16 ft . All said and done over 2 K . My complete 4 track will be around 1200 and that is everything you need , NO EXTRA PARTS TO BUY !Stainless marine 4 track and 4 Act , cables , thru hulls you talking over 2100!!!!!
BROWNIE 12-08-2011 07:11 AM
My, you must be a real innovator. Have you considered inventing anything else?
RunninHotRacing163.1 12-08-2011 07:15 AM
:poopoo::eek:
ROCK ON !!!!!!!!!!!!!!!!!!!!!:coolcowboy:
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!:drink:
BROWNIE 12-08-2011 08:00 AM
If you never have to invent or prototype anything, it is MUCH cheaper to make a product. Are you Chinese?
Rottiguy 12-08-2011 08:28 AM
Well you get what you pay for. everything i have ever bought from stainless marine was top quality and the service is too.
KEVLARKAT32 12-08-2011 11:40 AM
They make nice stuff and I believe it was Blue-water that made the first indicator in dash unit . I will tell you this I have a buddy with a 30 skater that went thru 6 cables in 2 yrs from Stainlerss marine
audacity 12-08-2011 12:37 PM
if they are not calibrated correctly...as in; the cable cannot hit the stop while the drive or tab is still moving. even a millimeter or two over a period will fray the cable and then snap it fairly quick after the first strand in the cable gives. this is the only trade off for the thin flexible SSM cable.
ps...pop up style indicators are more susceptible to debris and the elements of an open boat. i've spent far more time servicing, cleaning, and calibrating SSM in an existing application VS. a Livorsi were all the upkeep is done at the drive and or tabs.
fastdonzi 12-08-2011 12:42 PM
I have had Stainless Marines No Slack cables on two different Donzi's for more than 10 yrs with no problems ever. If you adjust them correctly (as in they don't bottom out at either end) there isn't a problem with them.
audacity 12-08-2011 12:45 PM
Very true. They have made it happen for me and overnighted me parts for a race in the past few years...even 15 years ago they overnighted me their LED replacement bulbs on two different occasions.
28cigarettess 12-08-2011 05:10 PM
Looking forward to seeing your finished product. And to those critical of you...........two words..........FREE ENTERPRISE. Wonder if Bluewater sent SM a nastygram when SM came out with their indicator?
:popcorn:
