1075 Valve Springs
Old 12-19-2010, 01:53 PM
RBH
Registered User
Default 1075 Valve Springs
What brand of valve springs is everyone using on the 1075's when it's time to replace the stock ones.(seat and open pressure?) What roller lifter are you putting back in them.
RBH is offline
Old 12-19-2010, 07:08 PM
Bob Teaque has done a bunch of them.He probably stocks the replacement lifters and springs.His # is 661-295-7000
skater40 is offline
Old 12-19-2010, 07:38 PM
RBH
Registered User
Thank's we will give Bob a call.
RBH is offline
Old 12-19-2010, 07:42 PM
Are you staying solid roller or converting to hyd. roller?
Young Performance is offline
Old 12-20-2010, 07:51 AM
RBH
Registered User
Eddie going to stay with the soild
RBH is offline
Old 12-20-2010, 10:13 AM
Skatermac's Avatar
Isky Red Zone Lifters with EZ Roll upgrade option (no needle bearings) PSI Springs same specs as the 1075 calls for. Experimenting with this part of the engine will cause you a lot of heartache. Ask anyone who has run their push rod motor a little to long why Mercury has gone to dual overhead cams.
Skatermac is offline
Old 12-20-2010, 10:32 AM
PF Marine
Coolerman's Avatar
The EZ Roll lifters (needless bearings) are great http://www.iskycams.com/pdf/2010Catalog-pg28.pdf
Are the 1075's an .842 or .904 lifter?
Coolerman is offline
Old 12-20-2010, 10:53 AM
Skatermac's Avatar
I run .904s not sure what 1075s uses. My engines had .842 to start with, but they are not Mercury's.
Old 12-20-2010, 11:06 AM
RBH
Registered User
Had a two sets of Big Chiefs, I understand about experimenting and having heartburn. It's time they have 95 hours on them.
RBH is offline
Old 12-20-2010, 11:07 AM
RBH
Registered User
.842
RBH is offline
